Towed a Water Truck
Discussion in 'Towing & Hauling' started by 2Tundras, Jul 28, 2023.
  1. Jul 28, 2023 at 11:56 PM
    2Tundras
    2Tundras [OP] New Member
    Jeff
    2015 1794 Edition
    On Wednesday I towed an unloaded F-750 water truck out of a ditch with my 2015 Tundra 1794. The water truck was on it's way to put out the local 14,000-acre forest fire. Put it in 4WD Low and used a tow strap. Surprised the 20' nylon strap held(it tore 75% of the way through, though).
  2. Aug 3, 2023 at 5:12 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice save. Did it take 2 Tundras to do it?
  3. Aug 3, 2023 at 5:18 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I see a commercial in your future.
    Jaypown and Mattedfred like this.
  4. Aug 3, 2023 at 5:27 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Thanks for stepping up to help with the fires.
    Jaypown likes this.
  5. Aug 3, 2023 at 6:17 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    You are a good man. Your transmission technician will thank you some time soon.
    :spending:
  6. Aug 7, 2023 at 10:16 AM
    2Tundras
    Jeff
    2015 1794 Edition
    ...The Toyota pulling out a Ford would ruffle the feathers of the Ford PR department if it was a commercial, but too bad for them!
    ...What's funny is the whole job was hampered by the F-750 not having front tow hooks. Somebody ran the strap thru the frame corner or a motor mount or something.
    Cpl_Punishment likes this.
  7. Aug 7, 2023 at 10:34 AM
    EmergencyMaximum
    Well, I think these sorts of pulls are down to traction. Pretty sure any truck could have pulled out that f-750. At such low speeds, any vehicle can create extraordinary amount of torque.
    https://youtu.be/USytXbUPMDg
    BravoDeltaRomeo likes this.
  8. Aug 7, 2023 at 11:08 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    World's strongest men competitors pull full size buses (albeit on flat smooth ground). Traction and Torque is key.
