Tow mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by Noble, Mar 2, 2021.
  1. Mar 2, 2021 at 4:43 PM
    Noble
    Noble [OP] New Member
    2014 Tundracrew 1794 edition
    6in lift, hellwig stable, tesla radio, tow mirrors
    Just installed tow mirrors from topgearautosport. The LED and blindspot not working. I have reached out to topgear with no response. Has anyone run into this?
  2. Mar 3, 2021 at 9:51 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
  3. Mar 3, 2021 at 10:41 AM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Does your truck have blindspot already? And what do you mean by the LED - the LED strip in the front? They usually don't come on unless your headlights are on, unless you do some extra wiring to them.
  4. Mar 3, 2021 at 12:15 PM
    RobertD
    Robert
    DFW, Texas
    I would not be surprised if you never got responses from TopGearAuto. But provide some more info and members might be able to help you. If you Tundra already had the blind spot monitoring, your mirrors should be pinned for them and they should work. If you didn't have BSM originally, it would be a pain to get sensors and wire them to work with the mirrors. Is the LED the puddle light that will shine along the side/back of your truck? If so, you would have to run wiring for that. The Tundra doesn't have the pinned to the harness.
  5. Mar 3, 2021 at 5:58 PM
    Noble
    The led on the front of the mirrors (running light) and yes I have BSM. And yes I know the lights don't come on unless the other is on. The puddle light works. Looking back I would have never ordered if I had seen the reviews on facebook. Can't get any response from Topgearautosport. And looking at the reviews if I sent them back I probably wouldn't see my money. So this is why I am reaching out to see what I can do. I believe I can do the wiring just would have to figure out which ones are for running lights and which wires are for the BSM. Just curious if anyone else has ran into this. And if they know which wires are which. Thanks
    RobertD likes this.
  6. Mar 3, 2021 at 6:02 PM
    RobertD
    Robert
    DFW, Texas
    Hmm... the running lights should be working if your DRLs are on. I thought I had a mirror pin diagram saved but I'm only seeing a trailer hitch diagram. If I find it I'll post it.
  7. Mar 3, 2021 at 6:22 PM
    Noble
    Thank you. I'm going to start doing research on the web. But if you find let me know.
  8. Mar 3, 2021 at 6:40 PM
    TXTundra2722
    2015 Black Tundra
  9. Mar 3, 2021 at 6:50 PM
    biebs96
    PA
    Make sure you didn’t hit the dash button that turns off the BSM..
    Also there is a way to add small LEDs in the door sail panels that light up for the BSM system. This is functional for people who added tow mirrors to a vehicle with the BSM feature.
  10. Mar 3, 2021 at 7:13 PM
    Noble
    I might do that but still need to know the wiring diagram
  11. Mar 3, 2021 at 7:44 PM
    TXTundra2722
    2015 Black Tundra
    :annoyed:
    It's in the thread that I posted
  12. Mar 3, 2021 at 8:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagram post in my signature - you can download the full set of wiring diagrams for your year. You’ll need a few different diagrams to chase it down, but they are all in the same pdf: illumination, blind spot monitor, headlights, mirror heater, and rear view mirror (w/ memory) to name a few. Those will help you chase down the different pins on the connector.
