Tow mirrors 2021
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bmitchell2023, Feb 22, 2023.
  1. Feb 22, 2023 at 8:54 AM
    Bmitchell2023
    Bmitchell2023 [OP] New Member
    2021 Tundra TRD sport
    Looking to install tow mirrors. 2021 SR5 sport. I have heated mirrors. Wondering if the turn signal wiring is there from factory?
  2. Mar 27, 2023 at 2:28 PM
    14crewmaxSR5
    14crewmaxSR5 New Member
    NorthEast
    2014 Tundra Crewmax SR5 TRD
    Lift Blocks Onboard Air Air Bags Leer Cap Warn Hidden Hitch Bumper Badlands 12000 Synthetic Winch
    I have a 2014 SR5 that I added tow mirrors to, and the turn signal wiring was there from the factory, just plug and play. The mirrors I got (Boost Auto Parts) also have some back facing white led lights that require additional wiring, that I haven't done yet.
    Bmitchell2023[OP] and RobertD like this.
  3. Mar 27, 2023 at 2:35 PM
    RobertD
    Robert
    DFW, Texas
    @Bmitchell2023 this has been addressed a few times. The harness in your truck will have the turn signal wire already ran, so the new mirrors you put on if wired for the signal should work. I say should, because some folks who have gone with cheap mirrors off Amazon/ebay/etc have had some issues. Normally this is do to the harness pins between the mirrors and the truck having a difference, but once both harnesses line up the signal works. If you go with OEM or Boost, their harnesses match the truck so everything will be plug and play.
    Hope all that makes sense, good luck :thumbsup:
    starfish.pat likes this.
  4. Apr 1, 2023 at 6:11 AM
    Bmitchell2023
    Thanks
    RobertD likes this.
