Tow mirror suggestions
Discussion in '2nd Gen Tundras (2007-2013)' started by kameleon, Aug 18, 2018.
  1. Aug 18, 2018 at 8:31 PM
    kameleon
    kameleon [OP] New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Just picked up my 8.5ft x 20ft enclosed trailer and quickly found out that I need to get some tow mirrors asap! Need input! 2012 non-heated, no puddle light if that makes a difference.
  2. Aug 18, 2018 at 8:38 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check out 1A auto or send a message to @Roman of cook springs Toyota if you want OEM
    Roman and ColoradoTJ like this.
  3. Aug 18, 2018 at 8:39 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Tsoot likes this.
  4. Aug 18, 2018 at 8:40 PM
    Ebay item # 310896733264
    $59.60, I have them and they work great for when I tow my Camaro. Easy to take on and off, no vibration or scratching of paint and they came with a bag to store them in when not in use.
  5. Aug 18, 2018 at 8:52 PM
    I have 1A Auto driver's side starting to shake have had em about a year and a half, I'd stick with OEM
    Tsoot and ColoradoTJ like this.
  6. Aug 18, 2018 at 9:06 PM
    OEM
    The cheaper cost is forgotten long after the bitterness of lower quality nock off mirrors sets in.
    Pudge likes this.
  7. Aug 24, 2018 at 10:15 AM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Pudge likes this.
  8. Aug 24, 2018 at 12:10 PM
    Tsoot
    Tsoot New Member
    18 Plat White
  9. Aug 24, 2018 at 12:18 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I have the same for my truck. I put them on only when I tow. Little vibration, not perfect, but I can see down the sides of my toyhauler easily at most speeds. Makes lane switches with the trailer much safer.
  10. Aug 24, 2018 at 1:34 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    NOPE!
  11. Aug 24, 2018 at 3:00 PM
    Did you tighten the mirror screw? I did on mine and no vibration.
    OBXTundra[QUOTED] likes this.
  12. Aug 24, 2018 at 3:02 PM
    That's the same ones I have/posted. They worked great for me the few time I use them. If you tighten the screw the vibration issue is solved.
    OBXTundra likes this.
  13. Aug 24, 2018 at 5:16 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    There is no screw on this model that I can find. These snap on and over the existing allowing the power fold to work as well as the puddle light. The mirror is in ball and socket with no adjustment that I have found.
  14. Aug 24, 2018 at 5:22 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
