Tow Mirror BSM Confirmation
Discussion in 'Towing & Hauling' started by ldale, Feb 15, 2018.
  1. Feb 15, 2018 at 4:37 PM
    ldale
    ldale [OP] New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
  2. Feb 16, 2018 at 3:31 PM
    AGia15
    AGia15 New Member
    2018 Tundra Limited CM
    Just ordered for my 18. Hopefully they fit well. I’ll post pix after install. Have you experienced any issues with them vibrating in the wind in excessive amounts? I think I read that in another thread. I’m sure something can be done to reduce it regardless if there is.
  3. Feb 16, 2018 at 3:57 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Does it also have power fold? And memory?
  4. Feb 16, 2018 at 4:15 PM
    AGia15
    AGia15 New Member
    The ones I ordered don’t. The memory feature may work if you have it though.
  5. Feb 16, 2018 at 4:27 PM
    ldale
    Txk Tx
    No vibration to speak of. I just made sure that the gasket is seated correctly on the back of the mirror. Tightened the mounting nuts really good and hoped for the best. I have had good luck with this brand, as I had the non BSM version on my previous truck. Their warranty (LifeTime) seems to be good as well.
    No power fold or memory function on these as my truck is only a Limited.
  6. Feb 16, 2018 at 5:26 PM
    AGia15
    AGia15 New Member
    Good deal. Thanks for the info. I’m looking forward to it. Should help with the 26 foot TT.
  7. Feb 16, 2018 at 5:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'd be in if power fold and memory
  8. Feb 16, 2018 at 5:37 PM
    AGia15
    AGia15 New Member
    Try calling the company and see if they sell them somewhere.
  9. Feb 16, 2018 at 5:44 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I can live without memory. Power fold, signals/running light, bsm, puddle lamps is a must though!
  10. Feb 16, 2018 at 5:49 PM
    Pudge
    CT
    Yes this ^^^^
  11. Aug 17, 2018 at 7:51 PM
    supertran82
    supertran82 New Member
    Man
    DFW
    2024 Black Platinum Tundra
    does it have puddle lights?
  12. Aug 17, 2018 at 8:03 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    I wonder if us SR5 guys would be able to get the turn signals to work.
  13. Aug 17, 2018 at 9:40 PM
    Ditto.:popcorn:
  14. Aug 18, 2018 at 4:26 AM
    ldale
    Txk Tx
    I don't know for sure on the 18's , but they worked on my 16 and now on my 17 as well.
    BTBAKER likes this.
  15. Aug 18, 2018 at 6:22 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    No puddle light on any of the tow mirrors that I’m aware of. Guessing you have a Platinum (hence the power fold inquiry). The running lights don’t work on that model but the signals do work. I have the 1AAuto tow mirrors on my 2013. In 1.5years I’ve had them replaced under warranty 3 times. First had faulty wiring from the factory, second had lots of play in the folding arm, third the power fold stopped working occasionally and would only fold/un-fold half way. Warranty return process has been quick and easy though.
    Memory has been an important feature for me since the mirrors are in different spots for normal driving vs when they are extended for towing.
    BlueBottle[QUOTED] likes this.
  16. Aug 18, 2018 at 12:26 PM
    CMELLO
    CMELLO New Member
    2014 Tundra TRD Crew Max
    Nitto Terra Grappler 33" Rough Country Leveling Kit
    I have been looking for a tow mirror option and in previous years know that there were some mounting issues with aftermarket mirrors. I really like what you guys are saying here and just want to confirm that these mirrors from Trail Ridge are quality and don't have any play once they are installed.
    Thank you,
  17. Aug 18, 2018 at 1:10 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow thanks for the informative post! I will def stay away from 1A. Stick with OEM mirrors only.
  18. Aug 20, 2018 at 4:00 AM
    SOB
    SOB Big Member
    Ohio
    For me it was an acceptable trade-off. The OEM power folding tow mirrors are around $800 while the 1A mirrors are under $400. I knew I wasn't going to get OEM quality and would likely have some issues so I'm glad their customer service has been top-notch.
    ldale[OP] likes this.
  19. Nov 21, 2018 at 3:42 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
  20. Nov 21, 2018 at 3:52 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    Turns out clicking on the link you provided wasn’t that hard after all. :)
    I see they are heated, and have turn signals too. Do the turn signals work on your 17 Limited? I have a 16 Limited and that would be a cool addition.
    You’ve had them installed most of the year now - how have they performed? Worth it?
  21. Nov 21, 2018 at 5:07 PM
    ldale
    Txk Tx
    Yes the work flawlessly.
    Uhhhh.... likes this.
  22. Nov 22, 2018 at 4:47 AM
    RZRrider112
    RZRrider112 New Member
    Lance
    Waynesville NC
    2018 Blazing blue pearl crewmax limited tundra/2003 White Tundra SR5
    2.5 inch leveling kit, 285/70-17 Nitto Terra Grapplers
    Do they light up when the headlights are on or just when the turn signal is on?
  23. Nov 22, 2018 at 8:42 AM
    ldale
    Txk Tx
    Running lights are on anytime the lights are on...parking-headlights. Blinkers work whenever the turn signals are activated. What you see in the picture is the running lights.
  24. Nov 22, 2018 at 9:06 AM
    RZRrider112
    Lance
    Waynesville NC
    Okay thank you... Just checking...
  25. Mar 13, 2019 at 8:27 AM
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    I know this is an old thread but I just wanted to say thank you for pointing these out to me. I have just ordered a set and will be doing a video on the installation of them.
  26. Mar 13, 2019 at 4:33 PM
    ldale
    Txk Tx
    Nice ! Look forward to the video and review.
  27. Apr 9, 2019 at 5:16 PM
    wayoutwanderer
    wayoutwanderer @wayoutwanderer
    Austin, Texas
    2019 Tundra Limited CrewMax 4x4 in Cavalry Blue
    Anyone have an idea if these work on a 2019? I assume so...but 1A Auto told me today that they won't guarantee fit or warranty them on a 19. They're only listed up to 18 because they haven't updated the specs.
  28. Apr 10, 2019 at 1:22 AM
    wayoutwanderer
    Austin, Texas
    Went ahead and ordered them. OEM part numbers they replace haven't changed from 2018 to 19.
  29. Apr 10, 2019 at 4:41 AM
    Freezy
    Freezy New Member
    This may have been mentioned, but to they have the auto dim feature?
  30. Apr 10, 2019 at 9:22 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Damn should have purchased these earlier. I had a note that they were $254 but now they are $284. Was waiting for eBay coupon. :(
