Tow Hooks Stuck
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chase, Feb 24, 2020.
  1. Feb 24, 2020 at 5:21 PM
    Chase
    Chase [OP] New Member
    Chase
    2015 Tundra Limited
    I took off my front bumper today in order to install a new off road one. I need to take off my tow hooks as well to use the mounts, I used a breaking bar to loosen up one bolt on the first hook but it seemed to just spin after a few turns. The other bolt barely budged and the 2nd tow hook bolt ended up snapping in half while I was unscrewing it.... wth am I supposed to do to get these things off
  2. Feb 24, 2020 at 5:34 PM
    The internal nut that’s welded to the frame broke.
    A cutting torch would work for this issue.
  3. Feb 24, 2020 at 5:54 PM
    15whtrd
    15whtrd Mr. Blonde
    Next time you need to do some work on the truck, start spraying any of the bolts with PB blaster or something similar a few days in advance. Not saying it’s the cure-all but it gives you a better chance. Do you live in a state where they salt the roads?
  4. Feb 24, 2020 at 5:55 PM
    Chase
    Chase
    2015 Tundra Limited
    No, no salting in Texas.
    Also are you saying I should use a cutting torch to cut the bolts off?
  5. Feb 24, 2020 at 6:22 PM
    My 07 and my 14 hook bolts threaded straight through.......no frame nut......I removed my 07 and 14 tow hook bolts to mount my Ranch Hand twice. :mudding:but......I'll double check tomorrow.....
  6. Feb 24, 2020 at 6:45 PM
    Yes. You may have to drill out the bolts that snapped.
    Black Wolf likes this.
  7. Feb 24, 2020 at 7:05 PM
    Would make sense that there are welded frame nuts for the tow hooks too. Didn't think about that. :thumbsup: Crazy for a 15 to have messed up frame nuts like that. My 14 spent most of it's "life" in ND with an unforgiving climate and the hook bolts backed out without a breaker. :monocle:
    15whtrd likes this.
  8. Feb 24, 2020 at 8:24 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Same thing happened on one of my front swaybar bolts. The nut welded to the frame broke free and now it just spins with no way to get a wrench or socket on it.
  9. Feb 24, 2020 at 8:54 PM
    Chase
    Chase
    2015 Tundra Limited
    Well off to the body shop tomorrow, hopefully they can get the bolts out and tow hooks off. Starting to think someone got trigger happy when tightening the bolts originally.
    15whtrd likes this.
