Tow Haul?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Mar 22, 2020.
  1. Mar 22, 2020 at 12:47 PM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Hi,
    I can not find Toyota's recommendation on how to use tow haul mode. I used it last year and kept my 2019 4x4 OR in 4th, out of OD, the entire time. I recall some saying not necessary but not sure.....
    Everyone has an opinion but what does Toyota say? Does tow haul keep it out of OD except with cruising with no/low load?
    It's a drag because THE quickest way to fry a tranny is towing in OD....
    References would be welcomed addition!
    Thanks!
  2. Mar 22, 2020 at 1:05 PM
    Place shifter in D, select tow haul mode, happy towing. In this configuration, I was in 3rd and 4th most of the time.
    Coming down steep mountain grades, I would take the transmission to S, which puts you in 4th and downshift from there to maintain a reasonable speed.
    I tow in overdrive exclusively, with tow haul on, never replaced a transmission.
    Now if the transmission is hunting between 5th and 4th a lot, shift in S mode until grade is completed. The torque converter locking and unlocking (hunting) is what causes heat.
    T-Rex266, HulkSmurf14 and Hoff like this.
  3. Mar 22, 2020 at 1:08 PM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    From what I know the Tow Haul Mode will keep the engine at higher revs between shifts. This keeps the engine from lugging. You could also use the S mode to achieve the same results as the Tow Haul mode.
    HulkSmurf14 likes this.
  4. Mar 22, 2020 at 1:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    4.30 factory gearing allows you to tow well in OD...than enable tow/haul mode and you become a work-horse +
  5. Mar 22, 2020 at 2:29 PM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    I love Tow Haul :) It’s a cheap man’s super charger !!
    That combined with 4.30 rear end and cheap gas is a beautiful thing.
    Tundyfundy and HulkSmurf14 like this.
  6. Mar 22, 2020 at 3:20 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Here is the Quick Reference Manual page that addresses Tow Haul Mode
  7. Mar 22, 2020 at 3:22 PM
    Tundyfundy
    Bay Area, CA
    “Tow/Haul” mode is ideal for use when carrying heavy loads.
    When the TOW/ HAUL switch is pressed, throttle response and transmission control are optimized for the high performance operation. As fuel economy is reduced while in “Tow/ Haul” mode, deactivating when driving without a load is recommended.
    ‡ Upshifts occur at higher engine speeds to expand the use of lower gear ranges, enhancing power performance during towing and preventing repeated gear changes.
    ‡ Downshifts occur at a greater accelerator pedal angle to allow the vehicle to stay in a higher gear, reducing repeated gear changes.
    ‡ Downshifts occur at a lower accelerator pedal angle to allow the vehicle to stay in a lower gear, enhancing towing ability.
    ‡ When the accelerator pedal is wide open, upshift timing is optimized to effectively use the maximum engine power range available. When Tow/Haul is engaged, the opening angle of the electronically controlled throttle is wider for any given accelerator pedal position than normal, enhancing acceleration feeling and response.
    ‡ During uphill driving, the gear position is held to prevent repeated upshifting.
    ‡ During downhill driving, downshifting to lower gears will occur to effectively use engine braking. Refer to the Owner‘s Manual for more details on this system before attempting to use it.
    TTund16 and Cpl_Punishment like this.
  8. Mar 22, 2020 at 3:26 PM
    Tundyfundy
    Bay Area, CA
    Here is the Tow/ Haul section in the manual
    Cpl_Punishment and Hoff like this.
