tow haul
Discussion in 'Towing & Hauling' started by Jay661, Jul 3, 2017.
  1. Jul 3, 2017 at 7:37 PM
    Jay661
    Jay661 [OP] New Member
    Bakersfield,CA
    2014 Toyota tundra
    question. just got my truck a month a go 2014 tundra 4.6 sr5. with the 7 pin and look like it pre wire for break control so i spoke to the salemen and he said the previous owner removed the tow.haul.botton. is they a way to check because that make no sense to me to remove it. thanks
  2. Jul 3, 2017 at 7:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Can you post a picture of your dash where the tow/haul button normally would be?
    NewImprovedRon likes this.
  3. Jul 3, 2017 at 7:52 PM
    Jay661
    Bakersfield,CA
    2014 Toyota tundra
  4. Jul 3, 2017 at 8:02 PM
    boloson
    boloson New Member
    I dont think the sr's have tow haul mode. I was in my buddy's 2017 & he didnt have one
  5. Jul 3, 2017 at 8:05 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    My guess is that if it doesn't have the tow package it didn't come with the tow/haul button. Only a guess though!
    You could pop the blank out and see if there is a plug right behind it to make sure.
    EDIT: @bobeast brought up a good point, the presence of the connector may not mean anything.
    Hopefully someone will chime in with some expertise.
  6. Jul 3, 2017 at 8:05 PM
    Jay661
    Bakersfield,CA
    2014 Toyota tundra
    @boloson thank just checking before i.pull my travel trailer
  7. Jul 3, 2017 at 9:04 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Does your tundra have a transmission fluid temperature gage? If not, your dealer is FOS and yours does not have the heavy duty tow package (which would explain the missing Tow/Haul switch). I wouldn't rely too heavily on whether there is a connector for the switch behind the blank. Toyota likes to use the same harness across trim levels, so a connector there may not tell you what you think it does.
    MotoTundra likes this.
  8. Jul 3, 2017 at 9:19 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I am guessing that your truck does not have the Tow Pkg and someone installed the 7 pin plug just to tow a larger trailer at the time ? Just a guess.
  9. Jul 3, 2017 at 9:20 PM
    CM-LENNY
    San Diego, CA
    I don't believe any of the 3rd Gens have trans temp gauges. Something they eliminated.
    15whtrd and NewImprovedRon like this.
  10. Jul 3, 2017 at 9:44 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    bicklebok, Ericsopa and MotoTundra like this.
  11. Jul 3, 2017 at 9:45 PM
    Jay661
    Bakersfield,CA
    2014 Toyota tundra
    thanks every who took some time out your day to anwser my question.
    csuviper and MotoTundra like this.
  12. Jul 3, 2017 at 10:15 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Those cheap bas....umm I mean astute bean counters.
  13. Jul 11, 2017 at 6:39 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    I just bought a used 2016 SR5, it has a factory tow hitch but no tow/haul mode button. Is this a normal thing for them not to have a tow/haul button?
  14. Jul 11, 2017 at 7:36 AM
    chphilo
    chphilo Tundra addict
    Western PA
    For newer models, I think the tow package is standard in 5.7 and not even available for 4.6.
  15. Jul 11, 2017 at 8:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Bench seats have tow/haul ass button on the column shifter. Be sure to check there.
    Pudge likes this.
  16. Jan 30, 2020 at 11:21 AM
    TundraBlack
    TundraBlack New Member
    Does this go to the tow haul button?
