Tow Haul mode/ tow package
Discussion in '2nd Gen Tundras (2007-2013)' started by Eddie08Tundra, Nov 8, 2019.
  1. Nov 8, 2019 at 1:22 AM
    Eddie08Tundra
    Eddie08Tundra [OP] New Member
    Eddie
    08 Tundra 5.7 4x4 base auto
    1500 watt audio 2x10s Jbl, Rockford Fosgate Pioneer head unit
    Hello to all I am new to this forum.. So thank you in advance for your patience
    and knowledge
    I have a base 08 Tundra 4x4 Crewmax 5.7 without the tow package and without the tow/haul button
    I have since added the part on the drivers side of the AB60f transmission that sends Transmission fluid to an aftermarket transcooler mounted in front of condensor and a class III hitch.
    When I removed the radio bezel, to install an aftermarket headunit I noticed a female
    plug that seems it would plug into the tow/haul mode button.
    My question is IF I were to buy the tow/haul button and replaced the plastic plug in the bezel
    would it work? and would the transmission respond and go into "tow/haul" mode?
    or is it more to it for the trans to respond?
    Is the tow packed Tundras "programmed" differently
    every dealer I have contacted cant give a definitive answer
    Thank you
