Tow/haul mode, should engine use rpm to brake
Discussion in 'Towing & Hauling' started by 94slowbra, Apr 27, 2018.
  1. Apr 27, 2018 at 8:41 PM
    94slowbra
    94slowbra [OP] New Member
    john
    new orleans
    2016 TRD pro
    Just like the title says, when in tow/haul mode should the engine use rpms to help brake the truck? Noticed today that it didn't and didn't know if it was supposed to? Thanks
    ColoradoTJ likes this.
  2. Apr 27, 2018 at 8:44 PM
    15whtrd
    15whtrd Mr. Blonde
    I noticed my brother-in-law‘s first GEN does this when going down a hill. If he taps the brake it will hold the speed really well and engine break. I think our trucks do it too just not is noticeably.
  3. Apr 27, 2018 at 8:45 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I don’t know about in tow/haul mode. But there is a big hill I come down on the way home from work. It’s a 35 zone and if I am coasting and I get to 45-50 mine will downshift and start to slow down till I start to brake.
  4. Apr 27, 2018 at 9:01 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    So is it only supposed to do it on hills? All of my route today was flat but I watched it pretty close when slowing down and didn't see the rpms jump to help slow the truck down.
  5. Apr 27, 2018 at 9:15 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Mine also does it on hills without Tow/Haul being on, and it's only done it a handful of times when I hit the breaks really hard.
  6. Apr 28, 2018 at 2:42 AM
    Mine will do it also you have to just tap the break to activate it. I do not have to be in town haul mod for it to work but do believe it has to be at least 40 mph.
    JoshuaA likes this.
  7. Apr 28, 2018 at 3:41 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Mine will use the engine to slow the truck while in Tow/haul.
  8. Apr 28, 2018 at 3:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, I believe that you wont necessarily see RPMs jump because it uses engine not a downshift
  9. Apr 28, 2018 at 9:24 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    well i didnt have any hills and i didnt brake from over 40 so maybe i just didnt meet the requirements. next time i hook up ill try to just stab it a little and see what happens.
    on another note, the truck pulled the weight fine but boy does it need some help in the weight carrying department. with about 700 lbs in the bed and 3k worth of trailer i was squatting bad
  10. Apr 28, 2018 at 10:27 AM
    Watt maker, Black Wolf and JoshuaA like this.
  11. Apr 28, 2018 at 10:37 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    and there you have it. thanks for the link. ill load the car and trailer up once i help the rear end stay level and see how it really works
  12. Apr 28, 2018 at 1:22 PM
    It works really well. I’m telling you guys/gals, these trucks can work hard within the design limits.
    Can you imagine owning an older Dodge and the first thing you need to do is drop 3800.00 in a transmission to make it last?
