Tow brake wire harness sparked help
Discussion in 'General Tundra Discussion' started by FundraTRD, Dec 31, 2020.
  1. Dec 31, 2020 at 11:09 AM
    FundraTRD
    FundraTRD [OP] New Member
    Seattle
    Snow White
    Hey guys, coming on here after a situation this morning. The tow break the way it was positioned was bumping the knees so it needed to be moved. I unplugged the harness from the back and it just so slightly touched the metal part near the obd sensor area and I saw a small spark. Of of the tooth on the wire harness looks fried up a little bit, tried to plug it back into the prodigy tow brake and it won’t turn on.
    I’m not very good with these kinds of things, hindsight I guess I should have taped it before trying to reposition but never really experienced a plastic harness sparking up like this but the metal does stick out past the plastic.
    what harm do you think I have caused for it not to power up my prodigy tow brake anymore? Would I just switch out the harness or is it related to a fuse I could switch out? Your help is appreciated, and again I’m not very technical so if you could explain to me as easy as possible I’d greatly appreciate it - it looks like the black side of the 3rd picture uploaded
  2. Dec 31, 2020 at 11:15 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I would check your fuses. My bet is that you blew whichever one that circuit is tapped into when you shorted it out. That’s what they are there for.
    NewImprovedRon and FundraTRD[OP] like this.
  3. Dec 31, 2020 at 11:20 AM
    TXTundra2722
    2015 Black Tundra
    I second the above statement. If you need to disconnect or mess with anything electrical then disconnect your battery next time and that will negate this issue. Good luck!
    Leo's first and FundraTRD[OP] like this.
  4. Dec 31, 2020 at 12:33 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Once you're done with that, I would suggest you take your truck to a local autoparts store, or if you have an obd2 reader check the obd 2, make sure that bad boy is working. Nothing worse then being stranded and figuring out at that point in time that the obd2 is unresponsive. Check all other lights and electronics as well.
    FundraTRD[OP] likes this.
  5. Dec 31, 2020 at 12:45 PM
    FundraTRD
    Seattle
    Snow White
    Thank you, as for the wire/plug at this point I don’t want to keep the controller plugged in, ok to electrical tape it and securely (away from metal) under there. At this point if I take the fuse out, it would not have power running there anymore? Or how does that work
    (please excuse my lack of knowledge or I’m not asking correctly) and thanks again everyone
  6. Dec 31, 2020 at 12:54 PM
    blackdemon_tt
    Yes, exactly that. Wrap it up with electrical tape and it should be fine, if you can disconnect that pigtail so its not just handing there uselessly, then do that, and drop it in the glovebox or console where you can locate it when you need it.
    LOL, you reminded me of a time someone mickey moused my intercooler fan on my MR2 and the prongs came off the plug and made contact sparking a small fire right over my thigh... while driving and trying not to hit oncoming traffic or rip out my front bumper. while trying not to catch fire all at the same time.. No big deal from there... it was funny after the fact..
  7. Dec 31, 2020 at 1:02 PM
    FundraTRD
    Seattle
    Snow White
  8. Dec 31, 2020 at 1:03 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Electrical tape and secure, should be fine to just set unused. But if you have indeed fried a fuse I'm sure you'll need to replace it. Almost all fuses supply current to more than one thing, whatever else is on that circuit wouldn't work if fuse is fried.
    Good luck.
  9. Dec 31, 2020 at 1:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    The information I am finding shows that the Tekonsha uses a different part number for the 2007 Tundra, because the truck should be pre-wired for a brake controller (as long as the truck had the towing package).
    https://www.etrailer.com/tv-install-prodigy-p3-brake-controller-2007-toyota-tundra-90195.aspx
    Part number 3040-P for the wiring adapter.
    Also see attached Toyota wiring diagram.
    Looks like there should be a 30A Tow Brake fuse (in the main engine bay), as well the 15A Taillight fuse (in the instrument fuse box) that could potentially be the ones that are blown depending on which contact shorted out.
  10. Dec 31, 2020 at 1:45 PM
    FundraTRD
    Seattle
    Snow White
    Ugh what have I done. Well I checked and brakes and turn signals and everything else works normal. Hope it isn’t affecting anything else major I am missing, it does have the tow package that came from the dealer. I don’t usually tow anything at this time so it’s not urgent but I just want to avoid any safety issues and of course fix the issue in case I need it in the future. What would be the best way to find out what fuse is related to this tow brake is there a diagram I could use or would I be better off asking at the auto parts store when I go check that the obd is ok
    RainMan_PNW likes this.
  11. Dec 31, 2020 at 2:01 PM
    FundraTRD
    Seattle
    Snow White
    Oh duh sorry I didn’t see the latest post, thanks for providing me the info sir
  12. Dec 31, 2020 at 2:02 PM
    FundraTRD
    Seattle
    Snow White
    Thanks
  13. Dec 31, 2020 at 2:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Sure thing. If brake lights and all the rest are working, then you likely just popped the tow brake fuse in the engine bay.
    For sure check out the ODB connector with an engine code reader at the auto parts store to be sure it didn't do anything there, but you're probably fine.
    FundraTRD[QUOTED][OP] likes this.
  14. Dec 31, 2020 at 3:06 PM
    FundraTRD
    Seattle
    Snow White
    Pulled the 30A short fuse and indeed it is toast
    RainMan_PNW[QUOTED] likes this.
  15. Dec 31, 2020 at 6:49 PM
    FundraTRD
    Seattle
    Snow White
    Update
    firstly thank you all for helping and special shout out to the @RainMan_PNW
    was the fuse 30A short low profile, replaced it, plugged the obd reader and it reads/powers on, plugged the tow brake control back in and it powers on. Hopefully that’s that. Pulled it back out and carefully electrical taped up the wire connector and zipped tied it safely away and away from metal. Was a good learning experience. Will for sure be more careful in the future. Thank you all again and wishing everyone a safe end to this crazy year, and a great 2021.
