Touchscreen, side mirrors & acc power socket stopped working
Discussion in '2.5 Gen Tundras (2014-2021)' started by MrHorrible, May 13, 2022.
  1. May 13, 2022 at 11:06 AM
    MrHorrible
    MrHorrible [OP] New Member
    Jesse
    2018 Tundra SR5 Crewcab
    Hi!
    I have a 2018 SR5 TRD. Both my side mirrors my touch screen and the front accessory outlet all stopped working at the same time. I checked all the fuses in the cab and under the hood first visually, then for continuity & for power. Everything checks out but my stuff still doesn't work! Any suggestions what to check next?
    Thanks!
    Jesse
  2. May 13, 2022 at 11:18 AM
    Taco-Spike
    Two Trucks
    I'm sure you would have said this, but have to ask. Any new mods recently?
  3. May 13, 2022 at 11:37 AM
    MrHorrible
    Jesse
    No new anything, but you're right to ask! Thanks for replying!
  4. May 13, 2022 at 2:15 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ive had to reseat fuses before due to lost connection. So you dont have to reseat them all, do some research and see which sets control those functions. fully remove them and reinstall those and see if works.
    Still an issue, could try disconnecting battery for 20 min and see it things work when you reconnect. While you are at it, confirm your battery is good. If you still have the original battery, it may be due for replacement. They usually go out at 3-4 years. Trundras act funky with all sorts of issues, errors, etc if the battery starts going out....doesnt get and keep the required voltage for the systems, even if the truck starts and drives ok.
    Lastly, check for chewed wires, rodent damage.
    Taco-Spike likes this.
  5. May 13, 2022 at 2:28 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I lost 1/2 my windows a few weeks ago, I checked every fuse with a fluke (toned) all were fine, then I pulled them and one was blown but I'll be damned if the thing toned! (of course, it was UNDER the dash) I hope whoever chose to put the fuses under there has numerous really bad days!!!!
    Retired...finally and Taco-Spike like this.
  6. May 13, 2022 at 3:54 PM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Concur. Why UNDER the dash and not where you can see them without having your body all contorted just to see up here. Thank goodness for cell phones with cameras. Still a pain if you have to replace one.
  7. Nov 12, 2024 at 7:38 AM
    mtrayno1
    mtrayno1 New Member
    Mac
    2018 Dbl Cab 4.7L
    @MrHorrible - I'm having the same issue. Can you share how this was resolved?
  8. Nov 12, 2024 at 8:20 AM
    mtrayno1
    mtrayno1 New Member
    Mac
    2018 Dbl Cab 4.7L
    OK I found mine - It was a 5amp fuse under the dash labeled "ECU-ACC" ¯\_(ツ)_/¯
