TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
Discussion in 'Suspension' started by TOTAL CHAOS, Jul 9, 2018.
  1. Jul 9, 2018 at 10:14 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Toyota Tundra (2007-2018) - Race Series Lower Control Arms
    • Bolt on 4130 boxed and internally gusseted lower control arms feature an integrated CNC billet uniball cup.
    • Coil over shock tab fits aftermarket 2.5" and 3.0" shocks.
    • Features dual shock tabs to install an optional secondary shock.
    • 1" 100% stainless steel uniball replaces the factory lower ball joint.
    • Built in steering stops do not require any ball joint cradle modifications.
    • Heim sway bar link upgrade replaces the stock rubber sway bar link for ease of installation and eliminates binding during articulation.
    • Replaceable polyurethane pivot bushings include zerk fittings for easy maintenance.
    • *1.25" wheel spacers are required if dual shocks are installed with factory wheels.
    Click Here for more info on TC Lower Control Arms
    Not sure if you should upgrade?
    Please take a look at the following posts for more information on TOTAL CHAOS Lower Control Arms. Comment below if you have any questions.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    SoCal619, papasmurf and T-Rex266 like this.
  2. Jul 9, 2018 at 10:16 AM
    TOTAL CHAOS
    Corona, CA
    tundra_20, Inquiringone, Sas and 7 others like this.
  3. Jul 9, 2018 at 10:44 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    (as i watch this at work)........dont judge me!
    lol
  4. Jul 9, 2018 at 11:18 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I'm sure many others are doing the same :pccoffee:
    :anonymous:
  5. Jul 9, 2018 at 11:20 AM
    Not me...........................
    TheBeast likes this.
  6. Jul 9, 2018 at 11:56 AM
    TheBeast The Beach
    :spy::spy:
    Black Wolf likes this.
  7. Jul 9, 2018 at 12:00 PM
    Watched in bed while I'm sleepy
  8. Jul 10, 2018 at 8:36 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    If I am spending 3k, I am going to just go the whole hog and do LT..
  9. Jul 10, 2018 at 8:45 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    So on a stock setup, is the UCA and shock what's stopping the whole wheel from the fore/aft movement? With how easily it looks to move the LCA in that direction the UCA must see some serious forces no? I'd love to do LT but uniballs on a daily with road salt winters wouldn't be the greatest setup :(.
    lionix likes this.
  10. Jul 11, 2018 at 8:46 AM
    Bailey
    CO
    I thought the same thing, but ended up going stock width on my FJ.
    Didn't want to deal with the added width and extra goodies that go along with it (extended axles, tie rods, fiberglass, etc.)
    With a little shock tuning the setup was amazing. I'd do it again on the Tundra
  11. Jul 11, 2018 at 9:27 AM
    lionix
    You make a good point, still hard to swallow.
  12. Jul 11, 2018 at 9:53 AM
    n2deep
    n2deep Pavement Princess
    They should at least come with bypass mount. Pricey but nice
  13. Jul 11, 2018 at 10:10 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I said the same thing....but if you read the details on the tundra set - you can get bypass mounts :)
  14. Jul 11, 2018 at 10:10 AM
    lionix
    That's what I was hoping for. I noticed they do make a bypass race setup for other vehicles.
  15. Jul 11, 2018 at 10:11 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    See my comment above,
    They do offer secondary mounts.
  16. Jul 11, 2018 at 10:12 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    3rd bullet point
  17. Jul 11, 2018 at 10:13 AM
    lionix
    I see that, so is the pictured lca from a different vehicle? Any option for a extra hoop? I am also running RW wheels and will never run wheel spacers.
  18. Jul 11, 2018 at 10:18 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  19. Jul 11, 2018 at 10:19 AM
    TOTAL CHAOS
    Corona, CA
    When everything is bolted together you won't have as much play. Let me see if I can uncover a video I had of stock LCAs with the bushings blown out. You can see the movement in the arm. I'll post up if I can find it.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Yzed608[QUOTED] and Watt maker like this.
  20. Jul 11, 2018 at 10:24 AM
    TOTAL CHAOS
    Corona, CA
    I wanted to clarify a little. The TOTAL CHAOS Toyota Tundra LCA does have dual shock capability. If you choose to run a secondary bypass shock, you will need to purchase the TOTAL CHAOS Shock Hoops. Together you will have everything needed to mount a shock like this:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    chugs, joonbug, Black Wolf and 4 others like this.
  21. Jul 11, 2018 at 10:39 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
  22. Jul 11, 2018 at 10:51 AM
    lionix
    What about having to run wheel spacers?
  23. Jul 11, 2018 at 11:10 AM
    n2deep
    The picture posted does not have the bypass shock mount on it. So is it included or is that something that has to be added? I only ask because most don't have the ability to weld that on themselves and would prefer it be already built into the LCA. The TC upper mount would need to be welded but there are a couple of bolt on upper bypass mounts for the DIY without having to weld.
    dcsleeper408, 14burrito and lionix like this.
  24. Jul 11, 2018 at 11:12 AM
    n2deep
    Who reads ¯\_(ツ)_/¯ we just want to look at pretty pics of the actual part. haha
    Inquiringone, joonbug, Help and 6 others like this.
  25. Jul 11, 2018 at 11:23 AM
    lionix
    This ^^^^
  26. Jul 11, 2018 at 11:38 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    If you use another brand hoop(bolt-on), possibility of not fitting/lining up with the lower mount?
    joonbug likes this.
  27. Jul 11, 2018 at 11:56 AM
    TOTAL CHAOS
    Corona, CA
    1.25" wheel spacers are required if you're running a secondary bypass shock with factory wheels.
    The bypass shock mounts directly to the LCA, here is a different angle :)
    Only welding required is on the Upper Shock Hoops
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  28. Jul 11, 2018 at 11:57 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    No offense but 3k is basically gonna get you the catalogs to read about long travel:rofl:....so this really isn't a bad price for what you're getting boss.
  29. Jul 11, 2018 at 11:59 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Is there a reason there isn't a "gusset" on the secondary for the LCA? Looks like just a longer bolt is used.
  30. Jul 11, 2018 at 12:00 PM
    TOTAL CHAOS
    Corona, CA
    The TOTAL CHAOS Lower Control Arms are only compatible with the TOTAL CHAOS Shock Hoops. Geometry and spacing will be very different with the competition. Icon or similar offerings will not work.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
