Total Chaos rear bump stop brackets + King Shocks 2.0 compact bump stop
Discussion in 'Suspension' started by TheBeast, Jan 3, 2018.
  1. Jan 3, 2018 at 5:04 PM
    TheBeast [OP] The Beach
    from TC FB page...
    pretty legit setup.
    also spotted King 3.0” 3 tube bypass rear shock ..:spy::spy:
  2. Jan 3, 2018 at 5:41 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Pretty clean set up. You gonna get those?
  3. Jan 3, 2018 at 5:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looks really sweet. I wish my rear end looked that good.:spy:
  4. Jan 3, 2018 at 5:48 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Zaaaaammmmm
  5. Jan 3, 2018 at 5:52 PM
    n2deep
    n2deep Pavement Princess
    I like those bumps. But I just ordered ADS bumps and 3.0 bypasses for the rear.
  6. Jan 3, 2018 at 6:09 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Serious set up. Wish I had a need for something like that
  7. Jan 3, 2018 at 6:27 PM
    :spy::spy:
    wonder if that whole setup works with Deaver pack though. It shows a stock leaf pack.
    I kinda like the ADS bypass from MCM made specifically for Deaver leaf packs.
    Tacotundra[QUOTED] likes this.
  8. Jan 3, 2018 at 7:09 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Well. Those are sexy. I never had a plan, to build a go fast truck but, damn you. And that @KevinK guy...
  9. Jan 3, 2018 at 7:24 PM
    Tacotundra
    Vegas
    2022 Tundra
    I don't know. I'm gonna run the ADS bumps and brackets from MCM
    TheBeast[QUOTED][OP] likes this.
  10. Jan 3, 2018 at 7:28 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Mmmm I like! :cool:
    TheBeast[OP] likes this.
  11. Jan 3, 2018 at 7:52 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Good luck getting King to make those 3.0's :(
    signalbobby likes this.
  12. Jan 3, 2018 at 8:40 PM
    cant go wrong
  13. Jan 3, 2018 at 8:45 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Matt really needs some help with his web site. I didn't know ADS made bump stops or that Matt made mounts. Makes me wonder what else I'm missing.
  14. Jan 3, 2018 at 8:49 PM
    Tacotundra
    Vegas
    2022 Tundra
    Matt is working on getting the website updated and adding the new info to it. What i was told last was ADS is finishing up work on the bumps for the Tundras and would be available soon along with the brackets. They will be bolt on under the bed with no cutting of the bed. Maybe he will chime in and spread some info @M C M
    14burrito and TheBeast[OP] like this.
  15. Jan 3, 2018 at 9:02 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Probably a stupid question but what’s the benefit or difference between different bumpstops? Is there more to the concept than I’m aware?
    The Kings look highly adjustable
  16. Jan 3, 2018 at 9:09 PM
    I have 4 of those 2.0 king bumps, and they work well.
    @Almaboy
    Are you asking about bump diameter or dampening length (2” vs 4”)?
  17. Jan 3, 2018 at 9:11 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Either...
    I’m just curios as to how the differences affect functionality
  18. Jan 3, 2018 at 9:23 PM
    A 2” or 2.5” diameter body has different tuning capabilities. Yes, you can valve your bumps. Like the differences between a 2.0 and 2.5” bodied coil over.
    2” bump shaft vs 4”: a 4” bump is for the go fast boys that are really cycling their suspension hard. In reality, a 2” bump is all most people need for the occasional hard hit so you don’t bottom out your shock and the last little bit of suspension feels endless. Bottoming our shocks (or topping out shocks) cans cause a lot of expensive damage rather quickly. I would gladly let my bump take all the abuse.
  19. Jan 3, 2018 at 9:31 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Thanks for the info. Makes sense now :thumbsup:
  20. Jan 4, 2018 at 12:16 PM
    man that bypass is sexy....do I need it ? No..do I want it ? Yes !
    trayday, smslavin, ColoradoTJ and 2 others like this.
  21. Jan 4, 2018 at 12:18 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Will it look good on your truck? F*** yeah!
  22. Jan 4, 2018 at 12:19 PM
    will it look good crushing Prius ? hell to the yeah !
    Tacotundra and 831Tun like this.
  23. Jan 4, 2018 at 12:47 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    I mean... does anyone really NEED something like this?
    Hint: the answer is hell yes!! Because reasons...
    I saw a video of a 3.0” coilover and 3.0” bypass line-up for the tundra on their Facebook page. Did this get cancelled??
    831Tun and ColoradoTJ like this.
  24. Jan 4, 2018 at 12:49 PM
    I'm gonna go knock at their door..lol....they are down the street :)...
    831Tun and Tacotundra like this.
  25. Jan 4, 2018 at 2:45 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    I tried to purchase after that video and king has literally no information on the availability of the 3.0 shocks for the Tundras. Ive ran kings on 3 vehicles, but I am going to be giving money to another company now lol
    Tacotundra likes this.
  26. Jan 4, 2018 at 3:35 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I love it when the experts can explain these things in English. Thanks @ColoradoTJ!
  27. Jan 4, 2018 at 4:09 PM
    n2deep
    Yeah King doesn't want to make anything other than the standard OEM replacement. The reason I am working with Matt @M C M on the ADS Bumps and 3.0 bypasses. Hopefully the are built soon and can post up some pics.
    I ran one of the first sets of ADS 2.5 bypasses for the Deavers K37 pack. Does really well but I just need more - always need more. LOL
    TheBeast[OP] and Tacotundra like this.
  28. Jan 4, 2018 at 5:54 PM
    moaaaaarr...you selling those bypasses ? :spy::spy:
  29. Jan 11, 2018 at 12:32 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I'd like to pass the buck and blame @n2deep and @osidepunker for making me go fast. Those assholes.
    :rofl::mudding::rofl:
  30. Jan 11, 2018 at 6:22 PM
    n2deep
    HaHa
    KevinK[QUOTED] likes this.
