TOTAL CHAOS - 2007-2021 Toyota Tundra Upper Control Arm (UCA)
Discussion in 'Suspension' started by TOTAL CHAOS, Jun 12, 2018.
  1. Jun 12, 2018 at 12:07 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Upper Control Arms contacting your coil overs?
    Can't get your vehicle into proper alignment specs with 2-3" of lift?
    Looking to ditch the stock ball joint setup for a much stronger uniball UCA?
    TOTAL CHAOS has you covered!
    TOTAL CHAOS - 2007-2021 Toyota Tundra Upper Control Arm (UCA - #87500)
    https://www.chaosfab.com/product/2007-2021-Toyota-Tundra-Upper-Control-Arms
    - 100% Bolt-On UCA constructed of 4130 Chromoly.
    - Designed with added caster. When you lift a vehicle with factory upper control arms the wheel will move towards the rear of the vehicle (negative caster). With negative caster you will often have wandering or darting of the vehicle. The TOTAL CHAOS UCA's have positive caster built-in for lifted applications. This allows vehicles with 2.5-3" lifts to get back into factory alignment specs.
    - TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
    - Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel. Will allow for up to 2" of additional wheel travel when paired with extended travel coil over shocks.
    - Urethane bushings reduce bushing deflection compared to stock rubber bushings
    - 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
    - Complete grade 8 hardware kit is included.
    Order yours today!
    - Team TC
    info@chaosfab.com
  2. Jun 22, 2018 at 2:19 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    when those are paired with OEM king shocks, do they provide more travel or only when the top out spacer in the OEM kings are removed? I hear these have had noise in some snowy areas, is that a common complaint?
    Rex Kramer likes this.
  3. Jun 23, 2018 at 11:22 AM
    TOTAL CHAOS
    Corona, CA
    Sorry about the delay - our shop is out on vacation 6/22-7/08 :)
    KING's OEM shocks do provide additional travel in the front when paired with the TOTAL CHAOS arms. The exact number depends on how much pre-load or lift you're after.
    Areas that see snow often see road salts, mag chloride, or other harsh chemicals which can be harder on bearings and other components. Keeping these components clean and lubricated is key to lasting long and keeping everything quiet. A little TLC goes a long way.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  4. Jun 23, 2018 at 11:27 AM
    Samoan Thor
  5. Jun 26, 2018 at 8:28 AM
    TOTAL CHAOS
    Corona, CA
    Have a set of TOTAL CHAOS UCA's? Post up your TC equipped Tundra
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Erichudgins likes this.
  6. Jun 26, 2018 at 8:32 AM
    TheBeast The Beach
    yes ! I have the exact same setup up front :) KINGS/TC..a match made in heaven..lol
  7. Jun 26, 2018 at 8:59 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Just a spacer on mine :(
  8. Jun 26, 2018 at 9:05 AM
    TheBeast The Beach
    but you have a lot of lights :)
    Sunnier likes this.
  9. Jun 26, 2018 at 9:06 AM
    I know a guy that can help :D
  10. Jul 3, 2018 at 1:31 PM
    TOTAL CHAOS
    Corona, CA
    *** IMPORTANT ***
    Please watch this video before greasing your TOTAL CHAOS UCA's. DO NOT pump grease into the UCA without loosening the thru-bolt. Failure to do so will result in bushing damage and require bushing replacement.
    https://www.youtube.com/watch?v=xvMdAX2uybs
  11. Jul 3, 2018 at 2:32 PM
    OCxCEMENT
    OCxCEMENT HI :)
    Orange County, CA
    2018 Tundra Crew Max Cement TRD-Off-Road 4x4
  12. Jul 3, 2018 at 2:54 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    All that blue look bitchin!
    OCxCEMENT[QUOTED] likes this.
  13. Jul 3, 2018 at 3:33 PM
    TheBeast The Beach
    good stuff. thanks
  14. Jul 3, 2018 at 3:40 PM
    Vizsla
    Vizsla 2 = 2.5
    I hate greasing bushings...:cool: Thanks for the help with my decision!
    SoCal619, trayday, 831Tun and 4 others like this.
  15. Jul 3, 2018 at 4:19 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
  16. Jul 5, 2018 at 11:21 AM
    TOTAL CHAOS
    Corona, CA
    Nice!
    Keep the CHAOS coming :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  17. Jul 5, 2018 at 11:46 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Is that heim pivot arm good for use on a lift under 6"?
  18. Jul 5, 2018 at 12:23 PM
    TOTAL CHAOS
    Corona, CA
    It sure is - the heim pivot Upper Control Arm can be used on 2-3" lift and larger lift applications (6"+)
    The added caster and camber adjustment is great for the larger lift applications, but also helps for those looking to fine tune their alignment.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    tundra_20 likes this.
  19. Jul 5, 2018 at 2:47 PM
    5.7TRDProm
    Dara
    And maintenance is the same as the bushing version?
  20. Jul 5, 2018 at 6:39 PM
    TOTAL CHAOS
    Corona, CA
    It's a little different. The Heim Joints are lubricated with a Dry PTFE Lube where the Urethane Bushings get pumped with Synthetic Grease (we recommend Super Lube Synthetic Grease with Syncolon)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  21. Jul 6, 2018 at 5:09 AM
    5.7TRDProm
    Dara
    Gotcha gotcha! Looking to pick up a set pretty soon sometimes this month after my little roadtrip. Should be a nice birthday gift for myself haha.
  22. Jul 6, 2018 at 9:24 AM
    TOTAL CHAOS
    Corona, CA
    Agreed :thumbsup:
    We'll be back from vacation on Monday. Give us a ring if you have any questions or would like to order a set
    951.737.9682
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  23. Jul 6, 2018 at 9:46 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    483E6133-DFEA-4E79-9344-296E1D0E2B8A.jpg 7AF3FB2D-2543-46AA-A3BA-88E887376C43.jpg
    Everything I own is TC equipped, Tundra has 58k on the uppers with the original uniball. I went stupid and greased the bushings wrong and messed them up, just wish y’alls stock length lowers for the Tundra were more affordable...
    14burrito and trayday like this.
  24. Jul 6, 2018 at 3:23 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Running your uppers and lowers on the BD Tundra :cool:
  25. Aug 3, 2018 at 3:18 PM
    TOTAL CHAOS
    Corona, CA
  26. Aug 20, 2018 at 3:17 PM
    TOTAL CHAOS
    Corona, CA
    Repost from @5.7TRDProm
    Finally got around to order and put on some UCA and so long to the stock arms! I was on a long debate between the Camburg Kinetik Billets and Total Chaos ones only because of the suspension setup I am trying to put together down the road. Ended up with Total Chaos UCA and also bed stiffeners and I'm glad I did.
  27. Aug 22, 2018 at 3:05 PM
    zackbremer
    zackbremer New Member
    Da Z
    ive had em with fox and with king..either way great product
  28. Oct 24, 2018 at 8:26 AM
    TOTAL CHAOS
    Corona, CA
    TOTAL CHAOS Control Arms feature a two-stage powder coat which includes a durable clear coat. This provides a very clean and durable finish that will protect the product for many years.
    Want to order a set of Upper Control Arms?
    Please email info@chaosfab.com, call 951-737-9682, or visit one of our Authorized Dealers
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    5.7TRDProm likes this.
  29. Nov 12, 2018 at 10:57 AM
    TOTAL CHAOS
    Corona, CA
    Are you rocking a set of TOTAL CHAOS Upper Control Arms? We'd love to see your ride!
    Comment below with a pic or two of your TC equipped vehicle
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    SoCal619 likes this.
  30. Nov 12, 2018 at 11:29 AM
    5.7TRDProm
    Dara
