Total brake failure on 2006 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by jparkerri, Jan 6, 2022.
  1. Jan 6, 2022 at 6:27 AM
    jparkerri
    jparkerri [OP] New Member
    Jeff
    2006 Tundra 4WD Access Cab TRD V8
    I recently had complete brake loss when a flexible hose from the left front wheel to the steel tubing on the body broke. All the fluid was pushed out by the brake pedal and I had no brakes. I always thought that the second braking circuit would let you stop the vehicle but I had no brakes and there no fluid left in the master cylinder. Has anyone experienced this?
    Thanks for any advice.
  2. Jan 6, 2022 at 6:38 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    There's no fluid or a sealed system to create pressure in the calipers and wheel cylinders to counteract the rotating front rotors and rear drums.
    ABS regulates the amount of pressure each caliper and wheel cylinder will receive, but the system still needs to be completely sealed for it to function.
    Your mechanical parking brake will still work in the rear, but that's a parking brake.
    tvpierce and BlueCrushSC16 like this.
  3. Jan 6, 2022 at 6:47 AM
    jparkerri
    Jeff
    I thought that as of 1967, all vehicles had to have a dual master cylinder that would allow the brakes on at least two wheels to work. I remember on my old Ford van, the master cylinder had two compartments, one for each circuit.
    des2mtn likes this.
  4. Jan 6, 2022 at 7:24 AM
    des2mtn
    SW
    Tonto cover
    Ah, didn't initially catch that's what you're referring to. There are internal seals in our master cylinders that can fail. Perhaps they failed and the fluid was leaking between chambers internally?
    If the MC is okay, another thought would be that the rear shoes were toast and it wasn't obvious until you were relying only on them.
  5. Jan 6, 2022 at 7:32 AM
    2mchfun
    That is why mechanical parking brake maintenance and adjustment is rather important. Had an old daily beater once that lost brakes in traffic at about 30-40 mph. Had to put it into the curb really hard and luckily learned a lesson without any crash.
    TTund16, Aerindel and des2mtn like this.
  6. Jan 6, 2022 at 7:36 AM
    des2mtn
    SW
    Tonto cover
    Just Fred Flinstone it and stick a foot out the door
    15whtrd, bmf4069 and 2mchfun[QUOTED] like this.
  7. Jan 6, 2022 at 8:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    According to legend, a butt pucker has been known to defy the accepted laws of physics!
    https://www.youtube.com/watch?v=ZgERCGbP0w0
    :rofl::rofl::rofl::rofl::rofl::rofl:
    des2mtn likes this.
  8. Jan 6, 2022 at 8:55 AM
    shifty` Animals and insects don't do drugs
    My comment is totally OT here, but I got a chance to see Kris at the Opry a few years back. It was really sad for me, his earlier sports life really took a toll on the guy's brain, he couldn't remember the lyrics to a lot of the songs or would just up and forget lyrics or hum his way through sections. Not dissimilar from what happened with Glen Campbell, except Kris doesn't seem to have full-on dementia stuff. He was really apologetic and it was still a great show which I'm glad we didn't miss, but a very different experience than the last time I saw him with my dad back in the 90s.
    des2mtn likes this.
  9. Jan 6, 2022 at 4:21 PM
    Aerindel
    Aerindel New Member
    Montana
    Yeah, same thing happened to me when a tire chain slipped off one winter and tore out a front brake line.
    This was before I fixed my rear brakes/parking brakes. But not a problem as I was in thick snow so I just came to a halt. Got out and used some pliers to fold what was left of the brake line over on itself and crimp it closed. Worked well enough to get home.
    bmf4069 and des2mtn like this.
  10. Jan 6, 2022 at 4:24 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Scary stuff. Would recommended the wheelers stainless steel brake lines!
  11. Jan 6, 2022 at 4:30 PM
    des2mtn
    SW
    Tonto cover
    Careful, you remember what our friend blue said about those :rofl:
  12. Jan 6, 2022 at 4:30 PM
    2mchfun
    If you make the hose too strong, applying excessive force to it just causes more damages. Better to have an ez shear/minimal damage/ez to repair hose.
  13. Jan 6, 2022 at 4:45 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    What? I must of missed that one...
  14. Jan 6, 2022 at 4:47 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    The wheelers hose is as easy to replace as factory rubber but a lot more robust and longer lasting, I would think. Yes there is always a weak point in any system, but I'd still rather make the weakest point stronger...
  15. Jan 6, 2022 at 4:50 PM
    des2mtn
    SW
    Tonto cover
    I can't find the thread but dude went over the top with how these "can cause infertility".
  16. Jan 6, 2022 at 4:51 PM
    2mchfun
    The idea of the stainless hoses is to minimize expansion when you mash the pedal, which then delivers more pressure to the caliper pistons. Has little to do with making an indestructible system.
  17. Jan 6, 2022 at 4:51 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I can't even think of how one would come to that sort of conclusion... Haha.
  18. Jan 6, 2022 at 4:54 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Agreed the main purpose is increased performance. But I'd bet money a stainless one will outlast the factory rubber. Not to mention be less susceptible to road hazard damage. My thoughts anyways
    2mchfun[QUOTED] likes this.
  19. Jan 6, 2022 at 8:05 PM
    Aerindel
    Aerindel New Member
    Montana
    When I had my chain problem, the rubber was fine...it was the metal brake line section that tore out of the caliper
  20. Jan 7, 2022 at 3:58 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I remember that. Wasn't it PHM saying they were made from chinesium or something?
  21. Jan 7, 2022 at 4:42 AM
    E30andaMJ
    E30andaMJ New Member
    Bob
    06 double cab
    nothing YET
    I'm a new guy here so please go easy on flaming me but imho, the weakest part should be the easiest to access and r+r in any place or conditions you might encounter. Like the shear pin on an old outboard, hit a rock, snap the shear pin off, put another one in, no internal damage and back on the track with out dropping a lap.
  22. Jan 7, 2022 at 6:00 AM
    The stainless lines are just rubber brake lines with a stainless braided sleeve jacketing them to prevent external expansion. Otherwise, same thing. Not an issue.
    terrward likes this.
  23. Jan 8, 2022 at 4:55 AM
    tvpierce
    Maine
    They're generally Teflon (or some comparable material)
  24. Jan 8, 2022 at 5:52 AM
    Nice! That’s an extra layer of less expandable material. Always thought it had the rubber inside of there. They are still flexible like the factory lines, screw in at the same points like the factory lines and shouldn’t present any complications.
    tvpierce[QUOTED] likes this.
