Torque Wrench/Screwdriver
Discussion in 'Off-Topic Discussion' started by TruckyTruck, May 26, 2016.
  1. May 26, 2016 at 6:10 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    I'm in need of a small torque wrench or screwdriver that can do 8 pounds. I'll be using it to replace lenses on my Baja design lights. I've already cracked one set of lenses because apparently I can't do anything lightly... anyone have suggestions on an inexpensive brand? Or if not inexpensive, one that will measure accurately?
  2. May 26, 2016 at 6:33 PM
    Mike Tread lightly.
    south carolina
    You mean 8 inch pounds I hope to hell not 8 ft pounds like you tried?
    Try Sears ,ace someone like that.
    But in all honesty 8 inch pounds if you feel it just start to go from free to starting to get some drag your done that fast man.
    Black Wolf and TruckyTruck[OP] like this.
  3. May 26, 2016 at 6:53 PM
    TruckyTruck
    Gary
    Yeah I thought I wasn't doing it too tight the first time around...
  4. May 26, 2016 at 7:34 PM
    Mike Tread lightly.
    south carolina
    When the lens gets snug stop.. if you get alittle moisture you go 1/8 turn till it stops letting in moisture.
    TruckyTruck[OP] likes this.
  5. May 26, 2016 at 8:40 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That stinks. You are just that strong!!
    I'm sure the guys at Baja Designs can point you in the right direction.
  6. May 26, 2016 at 10:47 PM
    TruckyTruck
    Gary
    Not easy having that kind of strength :ballchain:
  7. May 27, 2016 at 5:56 AM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
  8. May 27, 2016 at 6:01 AM
    If you get a torque screwdriver, get it calibrated. We get brand new torque drivers in our cal lab that fail calibration right out of the box and have to be adjusted.
  9. May 28, 2016 at 12:08 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I have been happy with my Wiha torque screwdriver. Matluth where do you send one to get calibrated? I would hope that a higher end brand like Wiha is already calibrated pretty doggone close?
