Torque specs for 05 double cab 2wd. Lower ball joint nut.
Discussion in '1st Gen Tundras (2000-2006)' started by akhero, Oct 13, 2021.
  1. Oct 13, 2021 at 9:46 PM
    akhero
    akhero [OP] New Member
    2005 Toyota Tundra
    Does anyone know the torque specs for the lower ball joint nut and the 4 bolts?
    thx
  2. Oct 13, 2021 at 9:48 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I like 'good n' tight + 1 extra yank' myself but yeah i hear ya' on numbers....
  3. Oct 13, 2021 at 9:50 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    There is a great debate over the spec, but 50-70 is good…..
  4. Oct 13, 2021 at 10:07 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    I think my chillton book said 52ftlb, but I’m not looking at it.
  5. Oct 13, 2021 at 10:23 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    59 ft lbs for the 4 bolts.
    103 ft lbs for the nut.
  6. Oct 14, 2021 at 11:35 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I wrote this up a while ago when I did mine 2006 Tundra DC
    Step 9: Hand tighten the 4 bolts, add thread locker to the bolts (red) Or buy new bolts
    · Spec - 61 ft-lbf
    · 17 mm, new bolts might be different
    · Ease the torque wrench for accurate spec
    Step 10: Tighten lower ball joint castle nut
    · Spec - 103 ft-lbf
    · You can over torque to get the cotter pin to line up
    · Add new cotter pin
    Step 11: Attach LBJ to tie rod and tighten to snug
    · Spec - 45 ft-lbf
  7. Oct 14, 2021 at 3:48 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    jerryallday and FrenchToasty like this.
  8. Oct 16, 2021 at 8:05 PM
    G500XL
    G500XL New Member
    SA, Tx
    Sliver 05DC 2wd
    I'm doing the same job in the next couple of days on my 05 DC 2WD, just about to pick up another torque wrench. I was looking at the 2005-2006 FSM and I'm a little confused.
    I know that the nut is 103 FT IBS, and Tie Rod is 67 FT IBS
    But the 4 bolts listed on page SA-79 diagram shows 59 FT IBS, but on page SA-84 diagram shows 48 FT IBS and on page SA-87 it says to tighten to the 48 FT IBS.
    So 48 or 59?
  9. Oct 17, 2021 at 9:45 AM
    Cummins3500
    Logan
    @G500XL i did both my tundra and sequoia to 61 lbs on those 4 bolts. That video I linked is from 1stgenoffroad.
    Toyota did a recall/update on the lowers at some point. Wonder if the spec numbers changed then
    FrenchToasty and jerryallday like this.
  10. Oct 17, 2021 at 5:45 PM
    akhero
    2005 Toyota Tundra
    I did 60ftlb on the 4 bolts
    FrenchToasty likes this.
  11. Oct 18, 2021 at 12:09 PM
    G500XL
    G500XL New Member
    SA, Tx
    Sliver 05DC 2wd
    Thanks!
  12. Oct 19, 2021 at 9:28 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
