Torque pro
Discussion in '1st Gen Tundras (2000-2006)' started by snowman4evr, Dec 10, 2021.
  1. Dec 10, 2021 at 11:10 AM
    snowman4evr
    snowman4evr [OP] New Member
    2003 Toyota Tundra SR5 4x4
    stock
    Does anyone have the fuel trim pids?
  2. Dec 10, 2021 at 11:47 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Long term and short term fuel trims show up automatically for me.
  3. Dec 10, 2021 at 1:36 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    06 Short term fuel trim—Bank 1
    07 Long term fuel trim—Bank 1
    08 Short term fuel trim—Bank 2
    09 Long term fuel trim—Bank 2
    If thats wrong blame wikipedia OBD II PIDs
  4. Dec 12, 2021 at 7:37 PM
    snowman4evr
    stock
    Well, since I couldn't get the fuel trims to work, i decided to explore other options for our woes. After a comp check, turns out #8 had 40 psi, and #6 had 200psi. #8 went up to 100 after adding a bit of trans fluid, so I foresee a motor change in my future. I am using torque pro/android. Not sure why those are not showing up automatically.
  5. Dec 12, 2021 at 8:44 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I had some weird phenomenon like that with mine and I attributed it to the wireless obd2 connector I was using. I wasn’t sure, so I just returned it.
  6. Dec 13, 2021 at 6:14 AM
    shifty` Animals and insects don't do drugs
    Before jumping to that new motor conclusion, consider something could be stuck, and a full cleanout will help. Another forum member (kirbotc?) recently swapped his engine because no compression on 1 cylinder. Didn't bore scope as recommended, instead bought used engine, installed used engine, dealing with all kinds of issues getting it up and running. Tore down old engine, it was a stuck valve the whole time. Looked like the top-end had never been cleaned and PO used some seriously shit gas. All that work could've been avoided with a good top-end cleaning regimen, IMHO.
    You'd be shocked at what 2x-3x cycles of SeaFoam treatment can do. Project Farm did a great breakdown of it here, unpaid by SeaFoam, love this guy's channel:
    https://www.youtube.com/watch?v=agAWXnT4-EQ
    bmf4069 and dinosaur like this.
