Torque app- what bluetooth scanner to get?
Discussion in 'Towing & Hauling' started by frichco228, Jun 18, 2020.
  1. Jun 18, 2020 at 7:48 AM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I am towing more and would like to monitor transmission temp- what bluetooth scanner should I get for the Torque app? And guessing the ODBII scanner just sits in the scan port?
  2. Jun 18, 2020 at 7:49 AM
    frichco228
  3. Jun 21, 2020 at 3:55 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    That one is wifi - not bluetooth. As I recall, you want to run the wifi with an iphone running torque pro but you can use bluetooth if you are using an android device. I am running this bluetooth cheapie OBDII dongle with a cheapie android tablet loaded with Torque Pro. I monitor both the pan and torque converter ATF temps while towing. Some "how to" discussions in this thread....
    https://www.tundratalk.net/threads/towing-temp-comparison-07-18-vs-19-20s.766462/
  4. Jun 21, 2020 at 10:00 AM
    CBrider
    CBrider New Member
    Cary
    Eugene, OR
    2017 1794 Edition TRD Sunset Bronze Mica TRD exhaust
    Diamond Back Cover
  5. Sep 7, 2021 at 6:17 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    This OBD2 I used worked with both Android and IoS - Its called Kuulaa brand.. - If you need to run on iphone this is the one I would get. Probably around $10-25 depending on where you get it. Search the interwebs and I am sure you will find it.
    Also it works great with Torque Pro
    KUULAA ELM327 V1.5 OBD2 Scanner Bluetooth 4.0 OBD 2 Car Diagnostic Tool for IOS Android PC ELM 327 Scanner OBDII Reader
  6. Sep 15, 2021 at 6:06 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
