Torn rack boot...
Discussion in '1st Gen Tundras (2000-2006)' started by 04DCTundraMan, Jun 10, 2022.
  1. Jun 10, 2022 at 7:38 AM
    04DCTundraMan
    04DCTundraMan [OP] Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    Hey everyone, i noticed the boot on the rack and pinion (i believe) has torn. I included a picture of both sides. Am i just looking at replacing the boot, or maybe the whole shabang...i am uneducated in steering repairs, any help would be appreciated.
    TIA
    trueblue1981 likes this.
  2. Jun 10, 2022 at 8:07 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I believe you can order them directly from Toyota. You'll also need the two metal bands which need to be crimped with a special $20-$30 crimping tool (unless you wish to use zip ties like I did). Napa sells them and you can find them on Amazon as well. Be prepared to capture the leaking fluid from the steering rack.
    I would probably drain the fluid from the boots (dust covers), zip tie it and see how quickly the fluid fills the boots again. The one on the left that's distorted looks pretty bad.
    If it leaks back rather quick, you may want to get a new steering rack for $500-$600 from Toyota or a rebuilt one from Napa for $300-$400.
  3. Jun 10, 2022 at 8:21 AM
    04DCTundraMan
    Ryan
    Thanks for the feedback...yea thats kinda what im wondering, spending the time and money replacing a boot, then do a whole rack, or just do the rack and be done...ive been told the rack is on its way out, but its not loosing fluid so ive left it.
  4. Jun 10, 2022 at 11:53 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Replacing the rack is awful and the boot is easy and cheap. The boots are side specific. I bought a napa one and it lasted about 6 months so go OEM.
  5. Jun 10, 2022 at 11:59 AM
    04DCTundraMan
    Ryan
    that sounds like the option i am looking for at this moment. thanks for the help.
  6. Jun 10, 2022 at 12:06 PM
    trueblue1981
    trueblue1981 New Member
    2006 white tundra sr5 dc
    "You'll also need the two metal bands which need to be crimped with a special $20-$30 crimping tool"
    What does this tool look like?
  7. Jun 10, 2022 at 12:28 PM
    rock climber
  8. Jun 10, 2022 at 12:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I just used metal zipties from harbor freight :notsure:
  9. Jun 10, 2022 at 7:03 PM
    Jack McCarthy
    Bill
    North of Boston
    They make metal ones? I used plastic! :rofl:
    des2mtn likes this.
  10. Jun 11, 2022 at 3:16 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Who knew?
  11. Jun 11, 2022 at 4:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Shit, I did! LOL You can see one of them on the left side of the picture.
    link
  12. Jun 11, 2022 at 5:25 AM
    w666
    Maryland
    How do you tighten them? Pull them tight like an ordinary zip tie (except that the stainless steel shreds your hands as you do so?)?
    Tundra2 likes this.
  13. Jun 11, 2022 at 6:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pull em tight with pliers, and then twist off the excess
  14. Jun 11, 2022 at 6:26 AM
    04DCTundraMan
    Ryan
    So I went out to start looking at how to take it apart and get parts, and I have fluid now under where it’s torn. Would that indicated the rack is leaking?? Or just excess fluid?
  15. Jun 11, 2022 at 10:55 AM
    Jack McCarthy
    Bill
    North of Boston
    That boot was twisted and looked like it was ready to give. Yes, the rack is leaking but how quickly? Normally mine will get wet if I turn full lock and after a day or two of sitting it will dry up.
    If yours is constantly leaking and ready to spill it might be time for a new rack unless you want to tackle replacing the inner seal and I know that's only available on one side of the rack when I checked into it originally.
    I can't remember if it's on the driver or passenger side though.
  16. Jun 11, 2022 at 1:55 PM
    04DCTundraMan
    Ryan
    I’ve kept an eye on the reservoir for a while and it’s a slow leak if not just a seep. I’m gonna put a new boot on and see how long it lasts. I asked Toyota what they thought, their answer was replace the rack for $1900 lol. Stealerships.
    Jack McCarthy likes this.
  17. Jun 15, 2022 at 10:34 AM
    04DCTundraMan
    Ryan
    So I went to take my tire off and the wheels have been over tightened so badly I can stand on the wrench, I weight 220, and they won’t budge. The stealer is going to “fix it” in the morning, but should I be worried about damage to my studs? It’s been almost 2000k miles like this. I plan on raising hell and make sure they hand tighten them to spec, as well as never going to this shit hole again.
  18. Jun 15, 2022 at 10:55 AM
    rock climber
    If they are that overtightened then I'd have them replace the studs. Don't want stressed studs to fail and lose a wheel on the highway.
  19. Jun 15, 2022 at 1:57 PM
    Can't emphasize this enough. See this thread: https://www.tundras.com/threads/wheel-studs-broke-truck-rolled.108200/
    Reply # 32 on the 2nd page is what happened to me when I was in your exact position: https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-912#post-2617304
    Stupid part is, when I replaced my studs, I found at least one, maybe 2 others suffered the same fate in the last 20-30k miles prior to my ownership.
  20. Jun 15, 2022 at 2:32 PM
    04DCTundraMan
    Ryan
    Thanks for the responses. Toyota is picking up my truck from work and taking it to look at and I’ve told them the studs need to be replaced. I haven’t been told no yet, so I’m guessing they want to see it first. I’ll be pretty forceful about it being done regardless of what they say, as well as demanding they determine how torqued they are as they remove them. I’ll keep everyone posted.
  21. Jun 15, 2022 at 2:37 PM
    04DCTundraMan
    Ryan
    I plan to reference the top thread if I get kick back. I’ll be making sure this is all documented incase anything serious happens.
    shifty`[QUOTED] likes this.
  22. Jun 15, 2022 at 2:39 PM
    They may find when taking them off, they shear, just like mine did.
  23. Jun 15, 2022 at 4:35 PM
    Jack McCarthy
    Bill
    North of Boston
    Usually when they’re that right, they’ll only come off with the impact, but they shouldn’t be so bad it can support your weight. I’ve had to stand on mine to loosen and I’m 205 lbs.
  24. Jun 16, 2022 at 9:12 AM
    04DCTundraMan
    Ryan
    so toyota is telling me they are only 7lbs over lol, when i put my torque wrench on them last night they were at 150lbs...and i stood on it and it wouldnt move, any of them. i told them theyre full of shit and to document this for when i get into an accident. im done, theyre idiots and have the same person who tightened them putting them on. i think theyre giving me the least tightened one's setting...ill find out tonight when i go to take them off.
  25. Jun 16, 2022 at 12:11 PM
    04DCTundraMan
    Ryan
    After a long talk, as well as me showing them a picture of me standing on my tire iron, they are replacing all studs tomorrow.
  26. Jun 16, 2022 at 4:32 PM
    rock climber
    Lame you had to fight it so much, but glad they finally did the right thing!
  27. Jun 16, 2022 at 9:19 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Honestly the rack is $900-$1,000 and a pain in the a$$ to replace. $1,900 isn’t bad. Problem is, I’m 100% positive you need new upper and lower ball joints, and outer tie rods. Possibly also LCA bushings.
    These trucks were made with way under sized suspension components.
  28. Jul 22, 2022 at 8:45 AM
    04DCTundraMan
    Ryan
    figured id give an update....after over a month with no issues, and being too busy to get to it, i finally knocked it out. Hardest part was loosing the old tie rod that was stuck, but went smooth other than that. happy i didnt listen to the stealership...ill be replacing my other tie rod soon now that this one is fresh. thanks for all the help. went with the napa boot, cuz it was easy....ill report back how long it lasts.
    Kimosabe, FirstGenVol and Tundra2 like this.
