Topper fit?
Discussion in 'Tonneau Covers, Caps and Shells' started by Pariverpirate, Jun 27, 2020.
  1. Jun 27, 2020 at 12:17 PM
    Pariverpirate
    Pariverpirate [OP] New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    I have a 2015 double cab. 6.5' bed. I'm looking for a topper. I found one for a 2012 in great shape. Says it is off a 6.5' bed. Do you guys think this will fit? Inside dimensions are the same on the two truck.
  2. Jun 27, 2020 at 12:19 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Believe there's another thread about this somewhere. If I recall correctly, the biggest difference between the two is the thickness of the tailgate.
  3. Jun 27, 2020 at 1:28 PM
    ezdog
    ezdog New Member
    Gateway To The West
    The tailgate if the 3rd gen are 1.5” thicker than the gen2 so if the back door of the top needs to close into the outside of the tailgate the top is likely to be sitting that distance from the cab end for the back door to work.
    Pariverpirate[OP] likes this.
