Tools you carry
Discussion in '3rd Gen Tundras (2022+)' started by Wcartee, Jun 7, 2022.
  1. Jun 7, 2022 at 6:41 AM
    Wcartee
    Wcartee [OP] New Member
    Hey there,
    trying to put together a toolbox for my truck and just wanted to see what others are packing. Historically I carried most of my tools but just want to get an idea of what a good bare minimum would be. Thanks!
  2. Jun 7, 2022 at 7:32 AM
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    All I carry is a 2ft long breaker bar w/21mm socket for a tire change. I mean, it's a Toyota, right?
  3. Jun 7, 2022 at 7:37 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Its a Toyota so you dont really NEED anything, but since I offroad, its best to be safe.
    I carry a basic mechanics socket and screwdriver set, 2 small blocks of wood for using with my hi lift or to bang something back in place or loose, hammer, 2 ratchet straps, a small box of fuses, zip ties, a few feet of fuel line and a tube of JB Weld in case I puncture my gas tank on the trail.
    Outbound likes this.
  4. Jun 7, 2022 at 8:14 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Tape measure
  5. Jun 7, 2022 at 8:39 AM
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    Duct tape, zip ties, and a screw driver in case I need to take off the license plate and walk away.
  6. Jun 7, 2022 at 8:46 AM
    TopDawg1776
    TopDawg1776 New Member
    2022 Tundra TRD Pro Solar Octane
    TK1979, wing-2, TXBrit and 1 other person like this.
  7. Jun 7, 2022 at 8:51 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I just bought this last week and love it. Set the PSI and press play and it will auto stop at desired PSI with .5 accuracy
    TK1979 and 22PlatWCP like this.
  8. Jun 7, 2022 at 9:02 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Tire inflator, breaker bar, factory jack, battery booster pack.
    In the winter, I carry some recovery straps and recovery boards.
  9. Jun 7, 2022 at 9:07 AM
    Sunnier
    Sunny
    San Diego, CA
    Would this set if you apply it to a busted tank actively streaming gas?
    gosolo likes this.
  10. Jun 7, 2022 at 9:09 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    4-way tire tool, various wooden blocks, 1 gallon of antifreeze, 1 gallon of water, 1- 6 ton bottle jack, 1- 2 ton off road jack, machete, jumper cables, 2 jack stands, 2 wheel chocks, recovery strap, folding spade, roll of heavy duty trash bags, a full set of 1/2 and 3/8 sockets, and assorted bungee cords & ratchet straps.
    TK1979, Sunnier and beehivetundra like this.
  11. Jun 7, 2022 at 9:13 AM
    TopDawg1776
    yup that thing is great, use it a good bit
    TXBrit likes this.
  12. Jun 7, 2022 at 9:14 AM
    Sunnier
    Sunny
    San Diego, CA
  13. Jun 7, 2022 at 9:15 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Is that for measuring how far you get before you need to get gas again?:rofl::rofl::rofl::rofl::rofl:
    :anonymous:
    Notarobot, TXBrit and raspy87 like this.
  14. Jun 7, 2022 at 9:16 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  15. Jun 7, 2022 at 9:17 AM
    beehivetundra
    beehivetundra New Member
    2013 Black Tundra TRD
    This!
    I carry a full set of 3/8 sockets in metric and standard with wrenches. Dewalt 1/2” impact with sockets, axle nut socket, headlamps, extra valve stems. Factory bottle Jack, jumper cables, hammer or mallet, zip ties, bungees, tire plug kit. The rest of this list goes more into recovery but also maxtrax boards, full size spare, snatch strap, tow strap, shackles, hatchet and machete.
    When I write it all out it sounds like overkill, and perhaps for the Tundra it might be, but I’ve used any of these tools at one time or another helping someone else on the trail or the side of the road. If I’m not in a rush to go somewhere, I will usually pull over and assist someone that’s having car troubles on the side of the road. So I like to be prepared for myself and for those with me.
    DeafJam and texasrho83[QUOTED] like this.
  16. Jun 7, 2022 at 9:18 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    A self drilling screw with a rubber washer will hold for weeks, if it’s a small hole.
  17. Jun 7, 2022 at 9:19 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Speak softly and carry a big tool.
    innards from a broken ratchet, crack everything loose, then use hand muscles to twist everything apart. Keeps you from over tightening when going back together. This one has a hole I can stick a small screwdriver for a little extra leverage.
    gosolo likes this.
  18. Jun 7, 2022 at 9:20 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think for me it's just a matter of being stuck on the side of the road broke down needing stuff. I was a life long Ford guy before the Tundra Era :anonymous:
    I used to carry spare parts too: alternator, starter, belts, solenoids, battery, assorted nuts, bolts, screws, hoses....
    gosolo and beehivetundra[QUOTED] like this.
  19. Jun 7, 2022 at 9:22 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Used self tappers for the ol roadside radiator fix
    gosolo[QUOTED] and Sunnier like this.
  20. Jun 7, 2022 at 9:25 AM
    beehivetundra
    I’ve been meaning to carry more spare parts for mine. Particularly CV axles, driveline, UCA’s as those can really leave you stranded. But that’s because I wheel the hell out of it and want to be prepared for the inevitable. Other stuff like a fuel pump or alternator it’s hard to say when they will give up the ghost.
    gosolo likes this.
  21. Jun 7, 2022 at 9:52 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, all those spare parts were for the Fords I drove lol to be fair, my fords were mid-70s model F150s and F250s
    gosolo likes this.
  22. Jun 7, 2022 at 10:23 AM
    MadMaxCanon
    I have the waterweld variety but you could use the regular one, you would just have to stop the leak somehow first, or jack up the side of the truck enough to stop the leak.
  23. Jun 7, 2022 at 10:27 AM
    Outbound
    Aaron
    Northern Alberta
    For tools, I don't carry a huge amount. On a new truck these days there's a limited amount I'm going to be able to fix on the roadside.
    - OBDII bluetooth code reader (ELM 327)
    - Booster pack
    - Jumper cables
    - Freedom and Commie sockets with a ratchet
    - Swedish nut fucker
    - Multibit screw driver
    - Pliers
    - Side cutters
    - Snare wire
    - Ball peen hammer
    - Small pry bar
    - Chisel
    - Gorilla tape
    - Zip ties
    - Ratchet straps
    - Headlamp
    - Hand crank flashlight
    - Breaker bar
    - Gloves
    - Plug kit
    - Air compressor
    - Tow straps
    - Shackles
    Maybe a few other odds and ends that I can't remember. I also have a pretty decent trauma kit, a survival kit, an ultralight fishing rod and organizer box with lures, water, shit tickets, hand sanitizer, blanket, spare hoodie, and there's a pair of rubber boots and recovery boards in the bed. I'll probably have to add a few things as I now have a baby girl to take care of, probably spare diapers, ass cream wipes etc.
    Cougareb, gosolo and MadMaxCanon like this.
  24. Jun 7, 2022 at 10:42 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I’ve used a cheap plug kit on a sport bike to get myself home. And a small box of wax, instead of superglue, shaving wax out of a plastic works as a decent med temp seal. You can’t cook it, but a crayon is more helpful than just making pretty pictures.
    Sunnier and gosolo like this.
  25. Jun 7, 2022 at 10:42 AM
    Taco-Spike
    Two Trucks
    Med kit
    socket wrenches
    flat / phillips screw drivers
    allen wrench set
    ratchet straps
    rope
    bungees
    gloves
    4 way
    jumper cables
    knives
    jacket
    rain panchos
    wood blocks
    small towels
    spare prescription sunglasses and clear glasses
    spare bulbs
    flash lights / batteries
    have most of the above in both trucks, might be missing a few things
    gosolo likes this.
  26. Jan 7, 2023 at 7:59 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
  27. Jan 7, 2023 at 8:51 AM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    An interesting question, I can confirm from youthful ignorance that tub & tile caulk does not.
    Sunnier[QUOTED] likes this.
  28. Jan 8, 2023 at 1:55 AM
    wing-2
    wing-2 New Member
    I am not likely to attempt to do much work on a modern vehicle even with a garage full of tools. To that end, I carry a AAA Plus card. I do however like to be prepared. I have a tire repair kit and 12 volt inflator, a conventional bottle jack that I can easily get at, under the rear seat, and a large four way lug wrench. Also jumper cables, and a few other trinkets that aren't tools.
  29. Jan 8, 2023 at 5:26 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I carry a Matt's Off Road Recovery gift card. JK. It's a long way from Hurricane, UT to my stomping grounds. :)
