Tool mounts for truck bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraOCC, Oct 14, 2021.
  1. Oct 14, 2021 at 10:23 AM
    TundraOCC
    TundraOCC [OP] New Member
    2020 Metalic Grey Doublecab TRD
    6112/5160. shims. +2 coachbuilder shackles. 275/70/18 BFG KO2. Bora 1.25" spacers
    Hey guys, trying to figure out how to mount shovel and ax in the bed. I have a shell so using the rails doesn't seem to be a good option with a standard tool mount.
  2. Oct 14, 2021 at 10:26 AM
    Taco-Spike
    Two Trucks
    Molle bed panels
  3. Oct 14, 2021 at 10:28 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
  4. Oct 14, 2021 at 10:39 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    You can still use the factory Toyota accessory rails even with a cap. I used some steel flat stock from the local hardware store and bent it up with drilled holes to mount a hi-lift and some quick fists for the shovel in the bed of my old truck. I purchased stainless steel t-nuts for the factory accessory rails off a-mazon.
    https://www.tundras.com/threads/bla...ndra-the-limited-dc.55189/page-2#post-1655386
    Still mounted in the bed even after adding the cap and sleeping platform/drawer system!
    HulkSmurf14 likes this.
  5. Oct 14, 2021 at 10:40 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Mine are installed via "quick fist holders from Amazon" i just drilled and screwed them in under the rail. silicone the holes in the bed. Works great for my needs.
    shovels under the rail
    AM-JKLUUOMt1i9RgWfpqh4Hfjq80qNXnQTRqjTnA_9eda8b4d13d7be6ccd29b00d151228e7c43c5c64.jpg
  6. Oct 14, 2021 at 10:45 AM
    TundraOCC
    Awesome, thank you!
  7. Oct 14, 2021 at 10:54 AM
    2mchfun
    Fold down rear seat back mod and mount behind seat maybe?
    TundraOCC[OP] and HulkSmurf14 like this.
  8. Oct 14, 2021 at 11:58 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It’s very easy to make your own.
    I spent around $30 and have great shovel and axe mounts.
    2mchfun likes this.
  9. Oct 14, 2021 at 12:32 PM
    clarkritchie
    clarkritchie New Member
    2mchfun likes this.
