Took a new 2024 Limited for a test drive last night
Discussion in '3rd Gen Tundras (2022+)' started by Crashnrondo, Nov 6, 2024.
  1. Nov 6, 2024 at 7:54 AM
    Crashnrondo
    Crashnrondo [OP] New Member
    Ron
    Wisconsin
    I'm wondering if something was wrong with it. It honestly felt like it had the same power and get up and go as my 2021 Tacoma, so it was a real let down. Then when I pulled into the dealer and put it into park the RPM's dropped to about 400 then jumped back to about 1200 before settling out at a normal idle. That seemed really odd.
    I then took a 4th gen Tacoma out, that thing got up and moved like I expected. I ran out of time and the dealer was clueless so I'm going back to try different Tundra tonight
  2. Nov 6, 2024 at 7:56 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  3. Nov 6, 2024 at 8:14 AM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    The hybrid with 435 hp jumps right out when I floor it - e.g. to pass. I don't usually floor it though, it sucks gas...
  4. Nov 6, 2024 at 8:32 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My 22 gasser has too much power. Not too sure why the tester you tried didn't perform well. Maybe the e-brake was on!
    Try putting the Tundra into sport mode or tow mode. Also go through the gears using the manual shift but get an open highway for that and just step on it. Lots of fun!
    troutback likes this.
  5. Nov 6, 2024 at 8:36 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I imagine the RPM dipping while parking was the auto-stop/start feature. Mine did that all the time until I bypassed it so it always stays off.
  6. Nov 6, 2024 at 8:36 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I'm guessing the test drive truck was in eco mode. Next time put it in sport mode and hit the tow button. It should be a totally different experience.
    JDR76 and Crashnrondo[OP] like this.
  7. Nov 6, 2024 at 8:40 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Do tell how you bypassed the auto stop/start to stay off permanently.
    I've become used to hitting the off button every time I start the truck, but it would be nice to eliminate that step.
  8. Nov 6, 2024 at 8:41 AM
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    That rpm surge was the auto off feature thinking about kicking in.
    Crashnrondo[OP] likes this.
  9. Nov 6, 2024 at 8:42 AM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    The 3rd gen Tacoma is a dog compared to the tundra. I had two, a 2017 and a 2021. Put the tundra in sport mode and gun it and you’ll see. I have a hybrid but I’ve heard even the nonhybrid is wicked fast too for a 6000 pound truck.
    Tundraman479 and Crashnrondo[OP] like this.
  10. Nov 6, 2024 at 8:56 AM
    Crashnrondo
    Ron
    Wisconsin
    Alright I'm guess it was in ECO or something, and the auto shutoff makes sense. I hope to try the other truck tonight during daylight. Thanks
  11. Nov 6, 2024 at 9:59 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    You should be able to bark those tires in Normal or Sport mode. Turn hard right when going on your test drive tonight and see if you can smoke 'em.
  12. Nov 6, 2024 at 3:08 PM
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    Coming from a 2023 Tacoma, this tundra is a complete night and day difference.
    Raven67 likes this.
  13. Nov 6, 2024 at 3:27 PM
    Breathing Borla
    Northern Illinois
    not a lot of detail there but could also be the port injection cycle, these are port and direct injected
    Raven67 likes this.
  14. Nov 6, 2024 at 5:09 PM
    Crashnrondo
    Ron
    Wisconsin
    I drove a SR5 tonight, something wasn't quite right with the limited I drove yesterday. Even in ECO mode the truck tonight was way better/quicker, in sport mode in was a rocket. The dip in RPM I noticed is for sure the auto stop feature trying to kick in, I was able to reproduce it several times.
  15. Nov 6, 2024 at 5:14 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Even V8 in tow/haul mode feels like it pours its single digit MPG into rocket booster. Can't drive like that every day when your belly is appropriate for father of three.
  16. Nov 6, 2024 at 5:30 PM
    Hella Krusty
    Hella Krusty New Member
    You did a test drive, and posted before the second test drive on the same day? I wish I had your time to waste
  17. Nov 7, 2024 at 6:14 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    https://www.tundras.com/threads/auto-stop-start-disable.137612/
    I've had this module installed for 11 months on mine. No issues.
    Haven't touched that button since.
  18. Nov 7, 2024 at 7:38 AM
    Matt2015Tundra
    2023 1794 CrewMax
    BlackNBlu[QUOTED] likes this.
  19. Nov 7, 2024 at 7:41 AM
    g4waldo
    I have this one https://www.ebay.com/itm/125666096660
    The drawback is having to run a wire over to the fuse box on the passenger side. The cover as is doesn't go back on with the module plugged into the fuse box.
  20. Nov 8, 2024 at 9:13 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks for that info.
    I've decided to live with pushing the button to turn auto S/S off rather than messing with the wiring on my truck.
  21. Nov 8, 2024 at 9:47 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    The Amazon one linked is plug and play. Nothing to do but unplug the switch, install the cable and plug it back in.
    You can enable the start stop by pushing the button. Disabled on next startup.
    The way it should be….
    Raven67 likes this.
  22. Nov 8, 2024 at 10:00 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Mine has only come on during the drive home from the dealership about 2 years ago. Maybe the auto stop/start doesn't like me!
    Actually, I think it is more that the "battery is charging" message comes on so this auto feature gets disabled. It's been like that since we got the truck so I don't mind it :)
