Too Much Rake?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Badknees, Jan 25, 2021.
  1. Jan 25, 2021 at 4:48 AM
    Badknees
    Badknees [OP] New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Just finished adding TRD Pro rear shocks and 1" shackles. I also have 295/70 R18 Cooper Discoverer AT3 XLs on stock TRD OR wheels. The front lifted about 2" when I added the TRD Pros. I added 1" lift shackles to the rear but I'm actually sitting about 1.5" higher now. Just wondering if it's too much rake?
  2. Jan 25, 2021 at 4:55 AM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    Perfect amount IMO. Looks good.
  3. Jan 25, 2021 at 4:58 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Looks good. How’s the ride with those shocks? In the shock market with my 15’
    Saltyhero13 and Badknees[OP] like this.
  4. Jan 25, 2021 at 4:59 AM
    Badknees
    South Carolina
    Thanks for your advice!
    lonedrake[QUOTED] likes this.
  5. Jan 25, 2021 at 5:00 AM
    Badknees
    South Carolina
    Much improved ride over stock. I also added the front and rear sway bars which helps handling a lot.
    Brownsfanhere[QUOTED] likes this.
  6. Jan 25, 2021 at 5:04 AM
    redheelerdog
    redheelerdog New Member
    Sticks of Montana
    2012 MGM Tundra DC 4X4
    Looks good, that's a nice looking truck.
    Tundyfundy and Badknees[OP] like this.
  7. Jan 25, 2021 at 5:07 AM
    Badknees
    South Carolina
    Many Thanks! Had to get rid of all the chrome....well, almost all.
    redheelerdog[QUOTED] likes this.
  8. Jan 25, 2021 at 5:18 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I love the rake! I have never been a fan of the level look. The second you put a shovel in the bed it sags. I think your truck looks perfect
    LS3, Mr Badwrench, Terndrerrr and 4 others like this.
  9. Jan 25, 2021 at 5:21 AM
    Badknees
    South Carolina
    Many Thanks. You're right, even an empty trailer made her sit almost level:
    Terndrerrr, khunk and GIN•OKUMA like this.
  10. Jan 25, 2021 at 5:24 AM
    Lake.Life24
    Shawn
    Upstate, NY
    I am actually looking at the roadmaster active suspension this morning because I have a cap on my truck and stock suspension. It sits dead level and I can't stand it.
    Did you have to add spacers to wheels to run OEM wheels?
    Badknees[QUOTED][OP] likes this.
  11. Jan 25, 2021 at 5:30 AM
    Badknees
    South Carolina
    I had about 1/2" clearance (Clarence :)) between the UCA and Coopers. I added a 1.25" wheel spacer. I like the stance, but not the dirt all over the side of my truck when driving in the rain. I plan to try the BORA 3/4" spacers and see if they are any better. However, unless you're doing serious off-roading I'll bet you wouldn't need wheel spacers with the OEM 60 offset wheels.
    B_R_O likes this.
  12. Jan 25, 2021 at 5:34 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Ahhh got it! Yeah I am not one for off roading. The extend of me off roading is driving through hay fields. I do tow and haul heavy so I am looking for some suspension upgrades without jacking my truck up.
  13. Jan 25, 2021 at 5:52 AM
    Badknees
    South Carolina
    Please let us know how that Roadmaster active suspension turns out. I tow a heavy boat and might want to consider something similar one day.
    Lake.Life24[QUOTED] likes this.
  14. Jan 25, 2021 at 5:59 AM
    Lake.Life24
    Shawn
    Upstate, NY
    Will do!
  15. Jan 25, 2021 at 6:12 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Great Tundra! I had picked up a set of those rims for the '08 I used to have. They really look good with bigger tires on. Rake looks just right
    Badknees[OP] likes this.
  16. Jan 25, 2021 at 6:19 AM
    Badknees
    South Carolina
    Many Thanks. Yeah, I liked these better than most OEM wheels and I can't afford the black BBS TRD Pro rims!
  17. Jan 25, 2021 at 6:25 AM
    2mchfun
    Consider sumo springs. Works well if you have a full set on the truck then if you have a second set cut down to form a bump stop you can raise a bit with a jack such as hi lift and swap them in minutes for off road articulation if thats your thing.
  18. Jan 25, 2021 at 7:14 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Looks great leave it!
  19. Jan 25, 2021 at 7:17 AM
    Badknees
    South Carolina
    Thanks for the compliment. Leaving it alone is starting to look like the consensus.
    Mr Badwrench likes this.
  20. Jan 25, 2021 at 7:22 AM
    Gould71
    Gould71 Member
    2017 Platinum Midnight Black
    TRD swaybar, TRD shift knob, FN FX Pro wheels, Toyo AT/IIIs, VLED interior and puddles
    Here’s another vote for looks good as is. I did a similar suspension upgrade and think mine is a little too level. I’ll see how it looks when I start towing stuff this summer.
    BTW, what running boards do you have? They look great and run full length- I’m looking to upgrade.
  21. Jan 25, 2021 at 7:23 AM
    Lake.Life24
    Shawn
    Upstate, NY
    I will take a look! I am looking at those, Timbrens, and the RAS. I haul around a lot of equipment and tow my tractor so I am trying to find a system that will work best in those situations
  22. Jan 25, 2021 at 7:28 AM
    Badknees
    South Carolina
    Farm Boy! I do like it!
  23. Jan 25, 2021 at 7:30 AM
    Badknees
    South Carolina
    Thanks for the vote. I wish I knew about the running boards. They work great but we’re already on the truck when I bought it.
    Gould71[QUOTED] likes this.
  24. Jan 25, 2021 at 7:35 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Rake looks good on long wheel base Tundra trucks, but not so good on the short wheel base Tundra trucks Toyota stopped making a few years ago. In my opinion, short wheel base trucks look better leveled by lifting or lowering.
  25. Jan 25, 2021 at 7:37 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'm a raker. Looks good to me.
  26. Jan 25, 2021 at 7:49 AM
    Badknees
    South Carolina
    Thanks for the input. Here's mine leveled..
    Rex Kramer[QUOTED] likes this.
  27. Jan 25, 2021 at 7:59 AM
    Bronzeback
    Bronzeback New Member
    Which shackles did you go with?
  28. Jan 25, 2021 at 8:10 AM
    Badknees
    South Carolina
    I know the CB's are probably much better shackles, but I wanted a less expensive option until I can decide on a permanent solution. These are easy to install, 3/8" thick, powder-coated, and work well for my needs today...unless I decide to drop the rake a little:
  29. Jan 25, 2021 at 8:30 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I'm in the rake camp too. Looks good. Leave it.
  30. Jan 25, 2021 at 8:31 AM
    Badknees
    South Carolina
    4-10...
    Saltyhero13[QUOTED] likes this.
