Tonneau Cover w/ Factory Cleat Rail
Discussion in 'Tonneau Covers, Caps and Shells' started by Ckatz53, Nov 14, 2019.
  1. Nov 14, 2019 at 5:33 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Purchasing a tonneau cover here shortly. Wondering if the factory cleat rail/cleats can be/if they should be relocated?
  2. Nov 14, 2019 at 5:36 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Yes there are small flat brackets to drop them lower. When you purchase make sure you have the option that specifies you have rails so they will send you the brackets
  3. Nov 14, 2019 at 5:38 AM
    Ericsopa
    Ericsopa Old man and the sea
    I think it depends on the brand. They used the rails to mount my ARE. Didn't move them.
    Boerseun, Ckatz53[OP] and 7.62Tundra like this.
  4. Nov 14, 2019 at 5:53 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Assuming you're saying drop the cleats and leave the rails in place?
  5. Nov 14, 2019 at 5:57 AM
    Ckatz53[QUOTED][OP] likes this.
  6. Nov 14, 2019 at 5:58 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Like another said it depends on the brand. For bakflips they have brackets that extend down. You drop the rails lower. It's basically a flat piece of metal about 2" wide x 3" or so long with 2 holes. 1 bolt goes in the existing threads, the other bolt goes through the rail and clears it out of the way for the clamps to install the cover
    Boerseun likes this.
  7. Nov 14, 2019 at 6:05 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    As said above, some brands require the rails to be lowered and some not. My tonneau is attached to the rails in the original location - no need to move anything, but I have seen others that require moving them down. did not like the idea of moving them because of the way the lowering brackets are so I specifically looked for a cover that can be used with the rails in the original location.
    Ckatz53[OP] likes this.
  8. Nov 14, 2019 at 6:06 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Gotcha. Looking at a Bak and see the options of with or without deck rail system. Appreciate it.
  9. Nov 14, 2019 at 6:07 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    What brand did you find for this?
  10. Nov 14, 2019 at 6:08 AM
    Boerseun
    Ferdie
    Sarasota Florida
    This is what the drop brackets look like. The attach to the original rail screw hole, and then the rail bolts to it in a lower location. I did not like that idea - it seems like those plates can bend, reducing the capacity of the rail.
  11. Nov 14, 2019 at 6:10 AM
    Boerseun
    Ferdie
    Sarasota Florida
    It depends if you want to go hard of soft cover. I have a soft Rough Country cover. It connects to the rail in 2 minutes. Easy to take off and put back on if I need to for whatever reason, and the factory rail location is still used.
  12. Nov 14, 2019 at 6:36 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Going for a trifold, but I'll keep that in mind.
  13. Nov 14, 2019 at 6:37 AM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Yeah I need my brackets secure for a $10k track bike. The drop brackets look flimsy as hell.
    Boerseun[QUOTED] likes this.
  14. Nov 14, 2019 at 6:40 AM
    Platinum Maximus
    Platinum Maximus New Member
    Tommy
    2020 Black Platinum 4x4 Crew
    I had my Rugged II cover installed on my 2020 Platinum by the Toyota dealer when purchased. As far as I know, the rails were not relocated & plenty of room for the cleats. It sits on top of the bed. I assume if it were a flush-fit cover, the rail would have to be lowered.
  15. Nov 14, 2019 at 6:41 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I have the Extang trifold that mounts to rails in original location. Didn't need to move them.
    Pistol0528 and Ckatz53[OP] like this.
  16. Apr 2, 2021 at 9:51 AM
    Is_It_Summer_Yet_13
    Is_It_Summer_Yet_13 New Member
    Danny
    2021 Tundra SR5 TRD Off-road
    Just curious, I bought a tundra 2 weeks ago and had them throw in bed cleats as part of the purchase price. The dealer is now trying to say they’re only giving me one cleat because they are only sold in singles. Tell me this, when you order a truck from the factory with bed cleats does it come with a single cleat? Based on the pictures from build and price they look like they come in a set of 4 when ordered from the factory? That’s how it was on my Tacoma at least. The picture on Toyota’s website shows multiple cleats in my opinion but apparently the dealer thinks otherwise. Feels like they’re pulling shady dealer tricks... Any info would be appreciated.
  17. Apr 2, 2021 at 10:02 AM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    I think they are telling you a story. Coincidentally I had never looked in my under seat storage for over 2 years and have been recently looking into upgrading my stereo and look what I found. Hopefully you can see the part number as well - clearly says 4 pack. Part # PT278-0C01B
