Tonneau Cover damage
Discussion in 'Tonneau Covers, Caps and Shells' started by dusted_tundra, Jan 8, 2019.
  1. Jan 8, 2019 at 4:54 PM
    dusted_tundra
    dusted_tundra [OP] New Member
    Samuel
    2015 Toyota Tundra SR5 Crewmax
    Icon Stage 5 Suspension Toyo AT 2 Xtremes 35s 18” method Race Wheels
    Installed a Bakflip Mx4 using the clip W/O the rail system around July 2018
    Damage- I now have 6 dent/ripples about 6 inches long (3) on each in the side of my truck where I mounted the clips
    I assume it was due to my bed flexing/vibrations in the desert/bumps on road but Does anyone else have this issue mounting their tonneau cover like this?
    Blueknights75 likes this.
  2. Jan 8, 2019 at 4:54 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Got any pictures of the damage?
    OR18TRD and dusted_tundra[OP] like this.
  3. Jan 8, 2019 at 4:58 PM
    dusted_tundra
    Samuel
    I am out of town right now but I will be back Friday. At first I thought it was there when I got the truck. I got my truck used with 29,000 miles) but I slowly noticed that more had appeared over time.
    Challenger1 likes this.
  4. Jan 8, 2019 at 5:05 PM
    dusted_tundra
    Samuel
    They aren’t really deep, but they are noticeable looking down the side. I removed the tonneau cover for now
  5. Jan 8, 2019 at 5:09 PM
    Adam New Member
    I have the revolver x4 and cant say i have the same problem....but i drive like a little bitch.
    dusted_tundra[OP] likes this.
  6. Jan 8, 2019 at 5:13 PM
    dusted_tundra
    Samuel
    I watched a Ford bed flex video and that’s what leads me to think it’s bed flex
  7. Jan 8, 2019 at 5:19 PM
    15whtrd
    15whtrd Mr. Blonde
    I think most of us would benefit from some bed stiffeners.
  8. Jan 8, 2019 at 5:20 PM
    dusted_tundra
    Samuel
    I just bought some yesterday for $170 they are arriving tomorrow
    15whtrd likes this.
  9. Jan 8, 2019 at 5:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Which ones did you get it? Hidden inside the bedside or exposed behind the tailgate?
  10. Jan 8, 2019 at 5:29 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I don’t have any damage from my MX4, but I haven’t been very tough on my Tundra.....yet.
    15whtrd likes this.
  11. Jan 8, 2019 at 5:30 PM
    dusted_tundra
    Samuel
    Total chaos exposed behind tailgate
    15whtrd likes this.
  12. Jan 8, 2019 at 5:31 PM
    15whtrd
    15whtrd Mr. Blonde
    Nice! I’ve been thinking about getting some. Trying to decide which one I would want, or should I be a nut job and get both!
  13. Jan 8, 2019 at 5:35 PM
    dusted_tundra
    Samuel
    I got the total chaos ones because it said it had a buggy whip mount and now I gotta get one once I finish suspension wheels and tires
  14. Jan 8, 2019 at 5:38 PM
    dusted_tundra
    Samuel
    I think if you mount it on the railing system it will be fine, i did it without the railing system
  15. Jan 8, 2019 at 5:39 PM
    lilharv321
    lilharv321 New Member
    They have a three year warranty, I would contact the bakflip
  16. Jan 10, 2019 at 5:11 PM
    dusted_tundra
    Samuel
    Hey guys how do I post a video from my phone to show you
  17. Jan 10, 2019 at 5:13 PM
    Challenger1
    Andy
    Cant post direct videos.. Need to provide a link
    Pictures are ok..
  18. Jan 10, 2019 at 5:18 PM
    dusted_tundra
    Samuel
  19. Jan 10, 2019 at 5:18 PM
    AZTundra
    Paul
    Phoenix, AZ
    Total Chaos Rear Channel Bed Stiffners appear to be built sturdy. I've got the MX4 as well, but haven't noticed any damage (tonneau cover is about 8 mos old). There is one small ding on one of the sections that appears to have been when folding the cover (maybe the foam padding isn't located in the right spot or maybe needs to be thicker?), I'm going to keep any eye on it.
  20. Jan 10, 2019 at 5:20 PM
    Blueknights75
    Ron
    Clayton, NC
    Mine has the same issue with the wavy plastic top bed rails....
  21. Jan 10, 2019 at 5:23 PM
    dusted_tundra
    Samuel
    Let me know if that link works for you guys!!!
  22. Jan 10, 2019 at 5:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Worked.
  23. Jan 10, 2019 at 5:25 PM
    dusted_tundra
    Samuel
    Gives you guys an idea on what to look for. It is like that on both sides exactly where I mounted my clamps
  24. Jan 10, 2019 at 5:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    I'll have to check mine when I get off work. I haven't noticed anything, but I've got the dropdown bracket for the factory rail.
  25. Jan 10, 2019 at 5:33 PM
    dusted_tundra
    Samuel
    I think that setup is fine. The clips I had clip on to the thin sheet metal and I feel like bumps/ bed flex pull the clips in a certain direction causing this to happen. These newer trucks are made with a thinner metal for weight and mpg
  26. Jan 10, 2019 at 5:36 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Tell me about it...i have to replace the sheetrock behind our bed.
    040Tundra and dusted_tundra[OP] like this.
  27. Jan 10, 2019 at 5:36 PM
    dusted_tundra
    Samuel
    Care package
    15whtrd likes this.
  28. Jan 11, 2019 at 11:12 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I too will need to keep an says it on my MX4. I just installed it to the sheet metal bed cap a couple weeks ago. Now I'm concerned! :(
  29. Jan 12, 2019 at 9:22 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Just saw the video. That is very odd. I don't have an MX4 and am unfamiliar with its mounting clamps. But now I'm wondering if this could be an issue with any other type or brand of tonneau cover that uses clamps on just the bed caps and experiences bed flex from off-camber trails.
  30. Jan 12, 2019 at 9:46 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Is the tonneau cover designed to flex with the bed or are the slats extremely rigid? I have an aluminum toolbox installed on the forward end of my bend and it seems to flex/move and has caused no problems. The Tundra hasn't gotten any lighter recently so I doubt that the bed material has gotten any thinner. Frame flex probably has more to do with the bed twisting. A C-channel frame aft of the front end could work if Toyota would add more metal to it, especially aft of the cab.
