Toilet seal problem
Discussion in 'Off-Topic Discussion' started by Tacogrande, Aug 21, 2019.
  1. Aug 21, 2019 at 6:40 AM
    Tacogrande
    Tacogrande [OP] New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    This toilet is about 8 years old and I just noticed black rubber sticky chunks in the bowl. Do these seals just go bad like this or is there something wrong with the water that is eating the seal?
  2. Aug 21, 2019 at 6:46 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    They go bad over time. That’s normal. Cut the water supply off, pull the tank and put in a whole new assembly. You can get an entire replacement piece with new valve for $20 at hone depot.
    T500, Kerch71 and YardBird like this.
  3. Aug 21, 2019 at 6:48 AM
    Be sure to drain it, after turning the supply off.
  4. Aug 21, 2019 at 9:40 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    And toilets are much heavier than you think!
    Blueknights75 likes this.
  5. Aug 21, 2019 at 10:16 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    You have chlorinated municipal water, don't you?
    Find replacement parts that tolerate chlorine.
  6. Aug 21, 2019 at 10:18 AM
    War Machine
    War Machine SSEM # 5 3MW
    No need. It will self drain when he removes the old assembly.
    graysquirrel, don3032, Brijab and 6 others like this.
  7. Aug 21, 2019 at 10:29 AM
    Talking the tank or entire toilet?
  8. Aug 21, 2019 at 10:45 AM
    15whtrd likes this.
  9. Aug 21, 2019 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    I’ve seen that many times. Just get a new flush valve and tank to bowl bolts with tank to bowl washer. Luckily that looks like a universal flush valve. Very common.
  10. Aug 21, 2019 at 10:54 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    This is what is in my toilet tank, I will have to have an engineer come fix it one day. BD47EC7E-7444-41C3-A2A5-1D2CA3D65786.jpg
    Darkness and 15whtrd like this.
  11. Aug 21, 2019 at 11:02 AM
    War Machine
    Disclaimer: I’m not a plumber or a scientist.
    All I know that when you start taking parts off of toilets, they drain themselves. Kind of pointless to do it ahead of time, if you ask me.
    Sas likes this.
  12. Aug 21, 2019 at 11:11 AM
    15whtrd
    15whtrd Mr. Blonde
    That must be one of those toilets that has a number 1 or number 2 flush LOL
    The part to the left is for the full flush and the flush valve to the right is adjustable for a urine flush.
  13. Aug 21, 2019 at 11:12 AM
    Omohundro
    Jody
    McMinnville TN
    It is! I like to call it “dropping the hammer”
    Darkness and 15whtrd[QUOTED] like this.
  14. Aug 21, 2019 at 11:12 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Wtf is that lol. That’s like an engine and a supercharger. U have to look how big ur load is that way u can see if u need the extra power or not lol
    15whtrd likes this.
  15. Aug 21, 2019 at 11:13 AM
    Omohundro
    Jody
    McMinnville TN
    #2 will suck the bottom out
    Darkness, War Machine and 15whtrd like this.
  16. Aug 21, 2019 at 11:21 AM
    15whtrd
    15whtrd Mr. Blonde
    Like, don’t be sitting down when you hit that button?! LMFAO
    Darkness and War Machine like this.
  17. Aug 21, 2019 at 11:33 AM
    Primalbryan
    Primalbryan New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    That’s very normal. As long as its not leaking just ignore it. I’ve seen them almost entirely deteriorate without leaking. If you try to tighten or mess with it though they could crumble and need to be replaced.
    15whtrd likes this.
  18. Aug 21, 2019 at 11:45 AM
    15whtrd
    15whtrd Mr. Blonde
    This is very true
  19. Aug 21, 2019 at 12:06 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
  20. Aug 21, 2019 at 12:40 PM
    Tacogrande
    Jeremy
    I knew we had a couple of plumbers here so I had to ask. It freaked me out because I was thinking what kind of chemicals are in the water to be able eat through a seal. We have city water. I have an account at a wholesale electric and plumbing supplier so I will get replacement parts for when I can get to it.
    There was a post here about a flapper valve that looked like a brain tumor but I can't find the post. It was crazy looking.
  21. Aug 21, 2019 at 12:48 PM
    JMcMusicman
    JMcMusicman New Member
    That's the worst advice ever! Is it better for the water to go down the drain or all over the floor?!?
  22. Aug 21, 2019 at 12:49 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would not fix until it starts to leak on the outside and get the water out of the tank before removing the inlet. That is unless you like wet floors. Toilets are heavy but not so much in 2 pieces. Be careful when reassembling the tank to the bowl. It is easy to crack something. I cracked the bowl on one where the tank sits. Fortunately it does not leak. Matching up the tank to bowl gasket can be a pain.
    15whtrd likes this.
  23. Aug 21, 2019 at 12:50 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    I replaced that part to my throne a few months back. Good as new
  24. Aug 21, 2019 at 12:55 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I am pretty sure he was being sarcastic...
  25. Aug 21, 2019 at 1:11 PM
    War Machine
    That’s somebody else’s problem.
    Ps3udonymous, JMB and T-Rex266 like this.
  26. Aug 21, 2019 at 1:55 PM
    Crawdad33
    Crawdad33 New Member
    Alan
    2016 Tundra 1794
    This looks like an earlyish American standard champion 4 flush valve. They had a run come out with a substandard rubber seal that basically melted over time, the only thing that generally needs replaced on those is the 4” rubber seal which can be found at Lowe’s or depot. The nice thing is you don’t even have to take the tank off to do it. Don’t try to replace that with a 2” universal flush valve as that will not fit the larger hole
  27. Aug 21, 2019 at 1:59 PM
    Liquid unlucky
    Liquid unlucky New Member
    North east Texas
    2019 Toyota Tundra
    None....yet few decals and a five star dragon Ball. Lift 4.5" in two years is the plan
    Buy a new toilet gut set it will improve your MPG and tire wear
    War Machine likes this.
  28. Aug 21, 2019 at 2:13 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    They do degrade over time. I sometimes over test my seals, especially after eating Taco Bell.
  29. Aug 22, 2019 at 8:56 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    You are supposed to that in the bowl not the tank. Company I worked for at one time shipped some homes to Israel to house Ethiopian immigrants. They thought toilets were for washing and drinking and did their business outside.
    Ajkkane[QUOTED] likes this.
  30. Aug 22, 2019 at 9:32 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Anyone for an upper decker?
