Toggle/Paddle switch configuration
Discussion in '3rd Gen Tundras (2022+)' started by Rockpig, Nov 11, 2024.
  1. Nov 11, 2024 at 6:25 AM
    Rockpig
    Rockpig [OP] You did what?
    08 Limited
    I'm trying to figure out the layout of the toggle/paddle switches under the infotainment system for the different trims. I know they are all laid out similarly such as w/wo locker, air suspension, traction control, etc. Could you please take a pic of your switch panel and what trim level you have. Looking to categorize SR to 1794LE and everything in between including TRD and non TRD trims.
    I'm in a 1794 LE, here is my layout.
  2. Nov 11, 2024 at 6:55 AM
    DRP
    DRP Old Member
    Dave
    From my 2023 1794. No TRD or Pro.
  3. Nov 11, 2024 at 10:03 AM
    Rockpig
    08 Limited
    DRP-I'm assuming the two to the right of the Hazard are for factory air suspension with auto height being the one on the right? Seems obvious but just want to double check.
  4. Nov 11, 2024 at 10:17 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    My 23’ 1794 with the TRD package has the locker as the first switch to the right of the hazard.
    Rockpig[OP] likes this.
  5. Nov 11, 2024 at 10:40 AM
    DRP
    DRP Old Member
    Dave
    Correct. The one next to the hazard switch toggles between manual and auto and the far right is for up/down adjusting when in manual mode.:thumbsup:
    Rockpig[QUOTED][OP] likes this.
  6. Nov 11, 2024 at 2:52 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    '24 Limited w/ TRD OR: Identical to OP
  7. Nov 14, 2024 at 11:00 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Pretty sure the manual shows all of these.
