To Vinyl or to plasti dip.....
Discussion in 'Detailing' started by LOTSOFTOYS, Jun 26, 2015.
  1. Jun 26, 2015 at 7:37 AM
    LOTSOFTOYS
    LOTSOFTOYS [OP] Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    The roof on my new Tundra has seen better days... fading a bit. I'd like to help it out and cover it. Either by having itwrapped flat black or I could plasti dip it. Once it's lifted, u wont be able to see the roof much and flat black will be almost invisible on the dark green truck.
    *vinyl is more expensive, not sure how long it'll last? Will rocks chip it?
    *Plasti dip is cheaper, I'm confident I can make it look decent... and you can touch it up. Also not sure it will last...
    Opinions?
  2. Jun 26, 2015 at 7:54 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I've never plasti dipped that large of a surface but it's always held up very well for me. Plus it's easy to touch up like you said. You could always plasti-dip then if you decide you'd rather it be vinyl then all you wasted was a couple $5 cans of dip.
  3. Jun 26, 2015 at 8:08 AM
    Mike Tread lightly.
    south carolina
    I believe I have seen more than a few guys over a tw do hoods. I know there is a site for nothing but painting plasti dip and you have 5 gallon buckets you put in a sprayer and go.
    I have olasti dip stuff on my tundra and my tacoma both. Tundra its been on there for 3 years now. I had one nick on it and it was faster just to peel it off and do it again then try to fix it.
    My back bumper on my tundra has vinyl (do to a non driving woman who hit the truck in the rear) it did have plasti dip and it transferred to her car nicely. if you go with vinyl make sure you use 3m vinyl only. Its not cheap but worth the money imo.
  4. Jun 26, 2015 at 9:06 AM
    Some use vinyl on their hoods...I haven't seen anything on the roof though. However, I haven't heard of vinyl being chipped on the hood....Grams has some vinyl on his I believe.
  5. Jun 26, 2015 at 10:20 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah I've seen Erics. He has vinyl on the hood and roof. But hasn't had it long enough to know how it holds up. There's a ton 9f uou tube vision dipping roofs. Takes time but doable.
    Good point tho above^ if I don't like it, I can peel it off
  6. Jun 26, 2015 at 11:08 AM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    If you want it really durable, maybe line X the roof?
    15max likes this.
  7. Jun 26, 2015 at 11:26 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No I don't need that. Just something to block the uv rays from causing further damage.
  8. Jun 26, 2015 at 11:28 AM
    Mike Tread lightly.
    south carolina
    Sand it and use a epoxy primer for now that will seal the metal from damage if you have rust in that area in question.
  9. Jun 26, 2015 at 12:42 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No, no rust. But pretty decent clear coat flaking and paint fading
  10. Jun 26, 2015 at 1:04 PM
    Mike Tread lightly.
    south carolina
    I would plasti dip if first man if it doesnt work your only out of pocket what 15 bucks and some prepared time in it. Plus it comes off.
  11. Jun 26, 2015 at 1:24 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah true. I'm gonna try to dip the badges first. Depending on how that goes I'll make up my mind
  12. Jun 9, 2016 at 5:36 PM
    DLack33
    DLack33 New Member
    Dylan
    2010 Slate Tundra SR5
    What do you use to touch up platidip? Just more plastidip?
  13. Jun 9, 2016 at 6:03 PM
    Seanson
    Seanson New Member
    2010 Tundra TRD Reg Cab Short Box
    5$ a can !?!:annoyed:
    It's over 22$ a can up here :canada:
  14. Jun 10, 2016 at 4:59 AM
    TNTundra08
    Blake
    2008 DC 4x4
    If the spot was smaller, I would spray some into a paper plate or something, use a Q-tip and just paint it back on. It'll dry and smooth back out.
    Holy crap lol. It's been a while since I've done it but it's cheap stuff.
  15. Jun 10, 2016 at 6:24 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    X2... make sure your first coat is very light and if I were you I would use at least 7 coats. That will ensure that if and when you decide to peel it off it should come off easily. The more coats you put on the thicker it is and the easier it is to peel. Also the obvious would be the thicker it is the more durable it should be.
