To Toolbox or Not to Toolbox
Discussion in 'General Tundra Discussion' started by contenderv07, Jan 10, 2022.
  1. Jan 10, 2022 at 10:53 AM
    contenderv07
    contenderv07 [OP] New Member
    Will
    So I got rid of my Chevy 2500 with the 6.5' bed. I really need to be able to put some recovery straps, first aid kit, etc... in the truck. So my options are...
    1. ESP plastic storage
    2. A slim fit UWS toolbox (and lose truck bed space)
    3. Something like a bakflip that has an option to add a toolbox (flipping expensive)
    When I got hunting I do like to flip the seats up and carry my clothes in plastic bins and its just easier to get them out from there instead of the bed. So what do yall think??? I'm kind of leaning towards the ESP metal 3 compartment storage but just looking for other views
  2. Jan 10, 2022 at 11:20 AM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Guess it depends on how you use your truck most of the time. I keep debating getting one because it would come in handy for my work
    (Tool belt, power and hand tools) but I would lose bed space and my tonneau cover. Plastic storage bin would be fine I bet
    contenderv07[OP] likes this.
  3. Jan 10, 2022 at 11:36 AM
    Cajun1977
    Cajun1977 New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
  4. Jan 10, 2022 at 11:50 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Do you need a toolbox?? To toolbox!
    Do you NOT need a toolbox? To NOT toolbox!
    Let's us know your decision-
    ezdog likes this.
  5. Jan 10, 2022 at 12:03 PM
    Northwoods22
    MN
    2013 tundra grade
    Am I correct in thinking you lose the tie hooks with the swing case?
  6. Jan 10, 2022 at 12:08 PM
    2mchfun
    Trail edition boxes are working out well for me. Some claim leaks, mine haven't leaked. My second choice, definately under rear seat. It is wasted space, most secure and dry. Preserves bed space, never know when you might need that space.
  7. Jan 10, 2022 at 12:11 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I cant live without my Shell personally but we each have different needs so you are on your own in the end.
    If you are using space for stuff that you need it is never wasted space?
  8. Jan 10, 2022 at 12:16 PM
    contenderv07
    Will
    I think the underseat metal ESP is gonna be the way to go. That way, I keep my bed space, and I keep my inside space since I can just close the lid and put my stuff on top of it. I will say the swingcase is still in the running though
  9. Jan 10, 2022 at 12:37 PM
    clarkritchie
    clarkritchie New Member
    ESP storage is killer.
    As for exterior storage, I couldn't find a toolbox that was narrow enough for me and also worked with my rack system, and so for the items I only occasionally want or need, I ended up with two 81mm ammo cans, primed and covered with Seymour truck bed coating, mounted to the rails using T-slot nuts off Amazon and some spacers, and then some ammo can padlock studs off eBay. Was about $100 all-in. I think it's about 6" deep. No leaks and has worked for me.
  10. Jan 10, 2022 at 12:48 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
  11. Jan 10, 2022 at 12:54 PM
    Kanobi13
    Kanobi13 New Member
    You could always make own under statage out if seeving trays ply wood and some cloth off Amazon or just cut under seats the size of straos for custom fit
  12. Jan 10, 2022 at 1:02 PM
    2mchfun
    Stainless steam pans like used in buffets are the ticket.
  13. Jan 10, 2022 at 1:03 PM
    contenderv07
    Will
    yea do that then maybe paint with flexseal to keep stuff from rattling around
  14. Jan 10, 2022 at 1:07 PM
    2mchfun
    I plan to do those and will likely put most things in zip loc bags to prevent rattle and to also be able to put dirty items back without cross contamination. I like minimal maintenance.
  15. Jan 10, 2022 at 1:15 PM
    Kanobi13
    Kanobi13 New Member
    I never got around to painting just kept the cut out of carpet no rattling i have hitches tools 10mm sockets and wrenches tow ropes bottle of whiskey no issues.
  16. Jan 10, 2022 at 1:18 PM
    contenderv07
    Will
    :cheers:
