To Skid or Not to Skid?
Discussion in 'General Tundra Discussion' started by ragofabrication, Jan 17, 2020.
  1. Jan 17, 2020 at 1:18 PM
    ragofabrication
    ragofabrication [OP] New Member
    Melissa Rago
    Hey Guys!!! Skid10?
    Absolutely! Skid plates are a simple necessity when it comes to overlanding and off-roading. The products we normally think about are the most popular such as rock sliders. However, riding on rocky trails, you have the potential to damage vital components, such as your lower control arms, shocks, gas tanks and similar undercarriage items. And nobody wants a significant unexpected expense.
    Aluminum or Steel? That’s the question.
    Aluminum: Aluminum and Steel Skid Plates technically do the same job, protect your vehicle from damaging the undercarriage. While Aluminum is the lighter option, it depends which trails you are running. If your off roading on simple trails and just need it as a precaution, Aluminum is the way to go.
    Steel: While Steel Skid plates are heavier, they endure harsher environments, slide on rocks easier, and less expensive compared to Aluminum. If you’re not worried about added weight, and are looking for a durable long-lasting option, a steel skid plate is the way to go.
    So the choice is yours! Are you going to be trail riding near the river, or jumping obstacles in Moabi?
    Where can I purchase?
    You can get them here-> Rago Fabrication offers both 1/4” Aluminum and 3/16" Steel Skid Plates, for all our trail riders, over landing, and off-roading customers. To take a load off your shoulders, we are offering a 10% discount on all our Skid Plates. You can purchase using code SKID10 at checkout.
    Flyinryank and sr5shark like this.
  2. Jan 17, 2020 at 1:31 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    @ragofabrication, do you have any plans to produce a 38 gal tank skid for a gen 3 Tundra?
    831Tun and Sunnier like this.
  3. Jan 17, 2020 at 1:57 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Is their an advantage in corrosion resistance between the two materials?
    Tundyfundy likes this.
  4. Jan 17, 2020 at 1:58 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @ragofabrication Will you be releasing a rear shock skids in the very near future?
    Flyinryank and Tundyfundy like this.
  5. Jan 17, 2020 at 2:17 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Aluminum is inherently corrosion resistant by nature. No real need to plate, paint or powder coat. Steel, on the other hand needs a plating, painting or powder coating for corrosion resistance. Steel, once scratched up is vulnerable, aluminum is not.
    Sunnier and Tundyfundy like this.
  6. Jan 17, 2020 at 2:19 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I see skid plates for Tacomas on you site, none for Tundras.
    TheBeast, Tundyfundy and porkitt like this.
  7. Jan 17, 2020 at 7:23 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Looks like you are offering 10 percent and free shipping for the general public.
    Is there anyway to get a forum discount or maybe a group buy going?
    porkitt likes this.
  8. Jan 17, 2020 at 7:26 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Why this over RCI?
  9. Jan 17, 2020 at 8:21 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    A few inquiries from forum members but all I hear are crickets from @ragofabrication
  10. Jan 17, 2020 at 8:39 PM
    18" TRD Off Road Wheels
    They offer control arm skids for the 3rd gens. Doesn't look like anything else for us at the moment.
  11. Jan 17, 2020 at 10:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Come on, Guys :rolleyes:, be nice. Rago is a great vendor, and they give us excellent deals on Black Friday. What they didn’t realize is that, unlike TacomaWorld that kicks up on the weekends, Tundras.com is all of us oldsters, well-employed and can afford Tundras, but post during M-F work hours. I’m sure going forward, she’ll know that after she lobs a grenade by posting a thread, she needs to hunker down for incoming return fire. :infantry:
