To Scotch Lck, or not to Scotch Lock. That is the question.
Discussion in 'Audio & Video' started by Randy Morton, Oct 13, 2017.
  1. Oct 13, 2017 at 4:36 PM
    Randy Morton
    Randy Morton [OP] Life takes its toll, please have exact change.
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    It'll be a while before I can have a good backup camera installed, but I can pick up a temporary fairly cheap. It's a simple wireless setup with a license plate camera and a receiver that I can plug into a power socket. My dilemna is getting power when the backup lights are on. Is there a connector I can plug into, or will I need to Scotch Lock into a wire somewhere?
  2. Oct 13, 2017 at 4:49 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Scotch-loks should never be an option, crimp or solder then heat shrink
    GavinG83 and Randy Morton[OP] like this.
  3. Oct 13, 2017 at 5:32 PM
    Randy Morton
    Randy
    That's why I'd prefer a handy connector somewhere.
  4. Oct 13, 2017 at 6:08 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    If you have the 7 pin trailer connector the center pin is the reverse circuit.
    Randy Morton[OP] likes this.
  5. Oct 13, 2017 at 7:33 PM
    Randy Morton
    Randy
    Perfect! Thanks! I'd forgotten about the trailer connector. Curving a connector to fit will be easy enough. Here's the pinout in case someone else needs it.
    NewImprovedRon likes this.
  6. Oct 15, 2017 at 1:43 PM
    Randy Morton
    Randy
