To Plasta dip or to not
Discussion in 'Wheels & Tires' started by rons23, Jun 28, 2015.
  1. Jun 28, 2015 at 8:33 AM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Gonna Plasta dip my rims today. I need some opinions from all takers. Should I plasta dip my lugs or leave them chrome. Wanted to offset, but not sure
  2. Jun 28, 2015 at 8:55 AM
    Any close up pix of it currently and something similar (or photoshopped) of it blacked out?
  3. Jun 28, 2015 at 9:12 AM
    I plastic dipped some fake bolts on my monster XD's. I went wheeling Friday afternoon. WhenI got back, most of the plastic dip was scratched off somewhat on several bolts on each rim. That's with 5 coats. I wouldn't recommend using on rims if your are wheeling in areas with a lot of wheel high brush/branches. I'm not going to redo plastic dip every time I come back from 4 wheeling. I gave it shot. Not for me. (glad I didn't do my bumpers)
  4. Jun 28, 2015 at 9:39 AM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Whats gonna happen every time you have your tires rotated? When the tech slides the socket over your lugs its probably going to mar them up!
    rons23[OP] likes this.
  5. Jun 28, 2015 at 10:44 AM
    rons23
    Ron
    Kill Devil Hills
    Thanks guys, not doing anything off-road, and the wheels are going to be temporary. I didn't think about rotation, I will leave them chrome and post pic when I'm done
  6. Jun 28, 2015 at 10:47 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Personally I would not dip the wheels or any other item that sees heavy traffic (e.g., step boards, front bumper). I just hate having to redo the same thing over again. But it's just me.
    Just on the color scheme, I personally like black wheels with some contrast. I would leave the lugs as they are.
  7. Jun 28, 2015 at 11:53 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i plasti dipped my stock wheels. i only painted the face. so you could see aluminum on the sides and had contrast. yea dont paint lugs. i never had any issues with peeling. but i also didnt ride with them too long. i had them no longer than year. but it held up against car washes and etc.
  8. Jun 28, 2015 at 12:56 PM
    Branj
    Branj New Member
    Nate
    2015 TRD PRO
    I used plasti dip on my Tacoma to get rid of the chrome grille and rear bumper. Had it on there for two years no issues. It is all on how you apply it because if you do not allow enough time between coats (2 hours minimum is what I found works best) and apply too thick of a coat, the plasti dip will not hold up well. It says to apply a coat until object appears "wet" or something like that. FALSE. Treat it like a spray paint. MANY, light coats. 15-20 coats. You will know you have done a good plasti dip job if your entire surface feels smooth. It will also take a few weeks to fully harden so don't go wheeling right away. Personally I agree with matluth and robie56 on the wheel part though. It's not worth the time to do all four wheels only to have the shop/dealer use a pneumatic on your nuts and ruin all your time and effort.
    Black Wolf likes this.
  9. Jun 28, 2015 at 1:00 PM
    rons23
    Ron
    Kill Devil Hills
    Ok here's the finished product, I had wheels rotated not long ago so I'm good for a while. This truck has been babied and no off-road. This is also temporary until I can afford the rims I want. Looks a lot better blacked out. Any thoughts on thisuploadfromtaptalk1435521624740.jpguploadfromtaptalk1435521633277.jpg
  10. Jun 28, 2015 at 1:06 PM
    rons23
    Ron
    Kill Devil Hills
    uploadfromtaptalk1435522008449.jpgOk here's the finished product, I had wheels rotated not long ago so I'm good for a while. This truck has been babied and no off-road. This is also temporary until I can afford the rims I want. Looks a lot better blacked out. Any thoughts on this
  11. Jun 28, 2015 at 1:15 PM
    Branj
    Branj New Member
    Nate
    2015 TRD PRO
    Looks good. FYI you can use aerospace 303 on them to help protect the plasti dip, use an old t-shirt when applying.
  12. Jun 28, 2015 at 1:16 PM
    Plasti dip is cool stuff. Depends on placement and like you said, how it's applied. I have sage brush and some cacti on my property and I have no doubt that no matter how many coats, the sage brush or cacti will rip right thru it. Nasty stuff. It doesn't do wonders on my paint either. I applied 5 coats over the course of a week. Figured 5 coats was enough because it was rapidly becoming a pain in the ass for something purely cosmetic. My rims looked good , but not that good. This time of year I am not going to wait a few weeks for something to dry either. I'm 4 wheeling almost every weekend from here on out past hunting season.
    Branj[QUOTED] likes this.
  13. Jun 28, 2015 at 1:20 PM
    Came out good.
  14. Jun 28, 2015 at 1:26 PM
    I just remembered I have a couple grandsons that might (will) want to learn how to plasti dip my rim bolts. Problem solved. heh heh
    csuviper and Branj like this.
  15. Jul 3, 2015 at 8:43 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Question about applying Plasti dip. Do you peel off the excess after each coat, or do you build up several coats then peel it off?
  16. Jul 3, 2015 at 10:08 AM
    If you get overspray you can scratch / peel it off. If you get it running, just peel it off and start over.
  17. Jul 5, 2015 at 9:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Build up several coats before pealing. One coat and over spray is hard to remove. Ended up using some goo gone to get some of my overspray off.
    4+ coats makes a stronger better looking coat and easier to peal off as well
  18. Jul 6, 2015 at 9:56 AM
    tacouser
    tacouser New Member
    Chicago
    Thanks for the info
  19. Jul 6, 2015 at 11:41 AM
    csuviper
    Broomfield, CO
  20. Jul 6, 2015 at 5:05 PM
    Plasti dip held up quite well on my rims this weekend. I have 6 coats on the rim bolts. I used a high pressure wash on my rims this morning and no issues either.
  21. Jul 6, 2015 at 5:59 PM
    ^^ a lot to of mud, or just to see as its durability as its raining down here.
