To lift/level or no?
Discussion in '2nd Gen Tundras (2007-2013)' started by SalsaTheTundra, Jun 17, 2020.
which one
  1. level
    86.4%
  2. way it is
    13.6%
  1. Jun 17, 2020 at 2:45 PM
    SalsaTheTundra
    SalsaTheTundra [OP] New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    So i installed my wheels and tires today. I had planned on doing 3in block in front and 1 in in the front. But after seeing this idk if i should. Opinions? they are pull off from a 2015 tundra. 275/70/18 toyo at2
  2. Jun 17, 2020 at 2:53 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    best picture everrrr
    lift it.
  3. Jun 17, 2020 at 2:56 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    i have more
  4. Jun 17, 2020 at 2:57 PM
    speckmon
    Thornton, CO
    it'll look good with a lift
    SalsaTheTundra[OP] likes this.
  5. Jun 17, 2020 at 3:06 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    So any 1in rear block recommendations? or UCA?
  6. Jun 17, 2020 at 3:09 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Still looks wimpy. Level it with good shocks.
    Black Wolf likes this.
  7. Jun 17, 2020 at 3:24 PM
    Toytec coilovers up front and shackles in the rear. Spacers and blocks ride rough.
  8. Jun 17, 2020 at 5:32 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    I’m on a budget. i’m 17
    Silverghost and Black Wolf like this.
  9. Jun 17, 2020 at 5:43 PM
    Ahhhhhh. I'm 46 and I try to budget myself. Doesn't always work...that's how I ended up like this due to this forum lol.
  10. Jun 17, 2020 at 5:50 PM
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    Level with Bilstein ride height adjustable shocks.
  11. Jun 17, 2020 at 5:57 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If not off roading then spacer lift in front and rear shackles are most affordable. Will need a front end alignment.
  12. Jun 17, 2020 at 6:13 PM
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    I would at least bring it up to level. I don’t really like the tilted in the front look.
  13. Jun 17, 2020 at 7:07 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    Yes. Any recommendations for rear shackles?
  14. Jun 17, 2020 at 7:07 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    That’s my plan. i have 3 in front blocks and just need UCA and rear blocks
  15. Jun 17, 2020 at 7:08 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    Good looking truck! id love a set of XB but i can’t see the price
  16. Jun 17, 2020 at 7:19 PM
    Yeah they were expensive, even during the group buy.
  17. Jun 17, 2020 at 7:33 PM
    17? Kuul. You came to the right forum for info. You are on a tight budget. What exactly is your budget? I'm going out on a limb here but you don't have blocks up front. You probably have "spacers" but not seeing much lift going on up front. Post pics of your front suspension/coilover setup. It's pointless to recommend whether you need blocks or shackles in the rear until we can see what's going on up front.........
    BTBAKER likes this.
  18. Jun 17, 2020 at 7:42 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I would really suggest at least going with Bilstein 5100 up front to level. You may find with that spacer, the ride will be harsh.
  19. Jun 17, 2020 at 7:43 PM
    Trooper2
    JR
  20. Jun 17, 2020 at 7:43 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    If you are 17, well done! Very nice truck and keep up the mods.
  21. Jun 18, 2020 at 6:20 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    i haven’t installed but here they are
    TheBlackPearl likes this.
  22. Jun 18, 2020 at 6:21 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
  23. Jun 18, 2020 at 6:26 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I limited my truck budget this year with what I could make from flipping free mowers as a challenge. Flipped 5 push mowers for about $800. Picked up 5100s and a TRD swaybar. Did my own install and had flip money to cover the alignment.
  24. Jun 18, 2020 at 6:29 AM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
  25. Jun 18, 2020 at 6:58 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    That’s a great idea!
  26. Jun 18, 2020 at 6:58 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    Dc2015[QUOTED] likes this.
  27. Jun 18, 2020 at 7:15 AM
    Trooper2
    JR
    If you still have original tires I'd say you did great! Not a front end expert, you could have other worn parts or an alignment needed.
    My 07 has what I think is a 3in spacer, 99% sure OEM UCA's. And 1" Maxtrac shackles. The ride is fine for the pavement.
  28. Jun 18, 2020 at 7:21 AM
    JGG10
    JGG10 New Member
    Minnesota
    2024 Lunar Rock Tundra Limited TRD Off-Road w/3" TRD Lift Kit
    TRD 3" Lift Kit, Method NV Double Black, Falken Wildpeak A/T4W 35x11.5r18
    I would for sure put a level/lift on if you are comfortable with it financially! Improves the look of any truck in my opinion. The spacers should work for you just fine as long as you are aware the ride quality may change; usually not a huge deal. A full suspension lift would obviously be optimal, but totally understand if it is out of budget.
  29. Jun 18, 2020 at 12:53 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    i’m on 275/70/18 toyo at2.
  30. Jun 18, 2020 at 4:15 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Bilsteins!!
