To flare or not to flare?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Badge618, Nov 8, 2021.
  1. Nov 8, 2021 at 3:48 PM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    So I purchased my Pro with the flares already on. I read a couple of posts on here about installing the flares and making sure to use some type of paint protection film to keep from wearing the paint off. I removed my flares today to see the condition underneath and like the way it looks without. I know in the end it is my decision ultimately but what does everyone think?
    EN2TUNDRA and Ahab like this.
  2. Nov 8, 2021 at 3:50 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Definitely a personal decision, but I’ve never been a fan of them. Just my personal opinion of course.
    icodeintx, avssuc, AggiePhil and 6 others like this.
  3. Nov 8, 2021 at 3:52 PM
    737fixer
    737fixer New Member
    Easy answer for me was to say never have them but your color matched ones look fantastic. For me it comes down to wheel poke. If the wheels/tires are level with the flares on then it looks professional and therefore good. If the wheels/tires stick in a bit then it looks stupid.
    Robster80, Ahab, ATV25 and 2 others like this.
  4. Nov 8, 2021 at 3:53 PM
    pandapro
    pandapro New Member
    I prefer no fender flares, but to each their own. If you like them, rock them!
    Fiberglass fenders is another story though!
    icodeintx, Ahab, ATV25 and 3 others like this.
  5. Nov 8, 2021 at 3:54 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    My .02 is that it looks better without.
  6. Nov 8, 2021 at 3:57 PM
    For me it would depend on your intended use of the truck.
    I put aftermarket wheels on that added a bit of poke to the tires, and I have some chips in the paint on my wheel wells and even got one on my door. My only concern is rust, and the flares could take the hits instead of my truck. Living down a mile of crappy dirt and gravel means that every trip my truck makes has two miles of rocks being flung up. Were I in your position I would get black bolts for the flares or get non rivet style and I'd run them to protect my truck. If you don't go anywhere to throw rocks, I'd take them off.
    Ahab, nvrgvup444, cowboyjack and 2 others like this.
  7. Nov 8, 2021 at 4:06 PM
    Badge618
    Lassen County, Ca
    If they do go back on they will have black bolts for sure.
    Jpd0144, Ahab, Piki and 1 other person like this.
  8. Nov 8, 2021 at 4:07 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    not to flare
    icodeintx, avssuc, Minarets and 3 others like this.
  9. Nov 8, 2021 at 4:22 PM
    Looks more aggressive with them. I have them on mine and they are Line-X'ed. If you do reinstall them, apply PPF to prevent paint rub.
    Ahab and Badge618[QUOTED][OP] like this.
  10. Nov 8, 2021 at 4:23 PM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    For what it’s worth, I like it without flares. Kind of like the badges or decals, some like them and some don’t.
    In the end, go with your taste.
    Ahab, Badge618[OP] and Pbed85 like this.
  11. Nov 8, 2021 at 4:23 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    better without.
    SPP
    icodeintx, Badge618[OP] and Pbed85 like this.
  12. Nov 8, 2021 at 4:34 PM
    I like them on the Tundra and I would change them to black bolts.
    Badge618[OP] likes this.
  13. Nov 8, 2021 at 4:39 PM
    Badge618
    Lassen County, Ca
    That's why I took them off to see if original owner had applied any and if not how bad the damage was/is.
  14. Nov 8, 2021 at 5:19 PM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    No flares.
  15. Nov 8, 2021 at 6:51 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have come to like flares on the Tundra. Almost looks to plain without them. Just my .02.
    2mchfun and Badge618[OP] like this.
  16. Nov 8, 2021 at 7:00 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I say looks cleaner without. Too busy and bulky looking with them on.
  17. Nov 9, 2021 at 4:15 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I like without with a little poke with the tires. I plan on changing my wheels down the road for a more aggressive offset to give tire poke without using spacers. I had about inch poke on my 4runner pro running 285’s and no issues with paint chips.
  18. Nov 11, 2021 at 11:05 AM
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    The VooDoo Blue Pro looks great with and without, IMO. I say “not to flare” and you can always go back when you get tired of that look!
    Badge618[QUOTED][OP] likes this.
  19. Nov 11, 2021 at 11:10 AM
    Badge618
    Lassen County, Ca
    I appreciate everyone's input. I think I prefer no flares however after removing them and having a professional look at the damage that had started on the paint due to a lack of protection film I think I will be putting them back on. I do have film and black bolts coming in next week. If the truck didn't have flawless paint everywhere else(for now) I would just run without. Thanks again.
    Tundra805 likes this.
  20. Nov 11, 2021 at 11:44 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I vote no flairs. But that's just my opinion. I still have stock BBS wheels and no poke to need them either though. What's the offset of your wheels? Do you mind having debris thrown up the sides of your truck? If no, no flairs. If yes, throw the flairs back on.
    And best color pro out there! :thumbsup:
    avssuc and Badge618[OP] like this.
  21. Nov 11, 2021 at 11:56 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    no flares vote here too. it results in a cleaner classier look to me.
    Hoff, Badge618[OP] and Pbed85 like this.
  22. Nov 11, 2021 at 1:24 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I think the no flares have it.
    I had flares on for a couple years then I smashed the shit out of one of them. Took them all off and wondered why I even had them on.
  23. Nov 11, 2021 at 5:14 PM
    UnicornHunter
    UnicornHunter New Member
    Brandon
    Smyrna, GA
    2021 Lunar Rock Tundra TRD Pro CM
    I like the way it looks both ways. I’ve had 3 Tundras without them, but I had a Barcelona Red Pro Tacoma with the flares and I was pleased with them.
  24. Nov 11, 2021 at 5:16 PM
    UnicornHunter
    Brandon
    Smyrna, GA
    I had the same truck without the flares, but I must say between the two pictures you posted, I like the one with flares better.
  25. Dec 12, 2021 at 5:42 PM
    Bajis
    Bajis New Member
    2016 Tundra Limited 4x4 MGM
    Trd suspension, RW wheels, 33’s
    I’m with you
    Pbed85 likes this.
  26. Dec 12, 2021 at 6:00 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Flares if you want to protect your paint a little if you drive off road or thru any kind of rough terrain.
  27. Dec 15, 2021 at 7:41 AM
    xuy
    xuy New Member
    2021 TRD PRO Super White
    I like the way it looks with flares. Looks beefy. Wondering what brand is that flare looks like rough country.
    I just got my 21 pro white. Debating myself on the flares as well. It costs a lot. Bushwacker plus match up paint total costs like 1300 bucks CAD.
    On my taco pro white it comes with factory black flares so all I did is 1.25 spacer and it does look better with wheels poke out just pass the flares.
    I will try the spacer on tundra first and see how it looks. Then I ll decide on the flares. I was told just apply 3m on the flare area and go without flares.
    If anyone has done that I wonder.
    jewsNbrews likes this.
  28. Dec 26, 2021 at 6:51 AM
    xuy
    xuy New Member
    Just put my long johns on they are simple easy serving the purpose and I love it. Having it 1*1.25 inch out driving back on dirty Alberta highways zero splash on the body.
    icodeintx, Tundra805, avssuc and 5 others like this.
  29. Dec 26, 2021 at 6:58 AM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    No flares.
    Pbed85 and jewsNbrews like this.
  30. Dec 26, 2021 at 6:59 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I vote no flares!
