To chrome or not to chrome?
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasrho83, Jul 10, 2019.
  1. Jul 10, 2019 at 2:24 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is there a chrome powder coat? Looking at rattle can chrome but unsure if it looks good enough and holds up to frequent handling. Might go matte black...still, the Warboys are all about the chrome.
  2. Jul 10, 2019 at 2:26 PM
    Ha! I have same! Mine is black plastic though
  3. Jul 10, 2019 at 2:26 PM
    @Mike suggested a way
  4. Jul 10, 2019 at 2:50 PM
    @texasrho83 I believe @Mike said for the one he made me he used a that clear hardener and for paint that brand Testors model paint
    I too wanted chrome but left black
  5. Jul 12, 2019 at 3:36 PM
    Mike Tread lightly.
    south carolina
    You have to use epoxy on the model... Now long as that's done in abs plastic your fine... If that's done in pla material not as strong.
    You have to drill out epoxy the main hold for the shaft with 2 ton epoxy.. let cure for two days.. drill epoxy to accept the tap and the threads..
    Edit the teeth are the weakest point in the model no matter how much infill you do.
    texasrho83[OP] likes this.
  6. Jul 12, 2019 at 3:41 PM
    Mike Tread lightly.
    south carolina
    You need to calibrate you settings on slicer and fine tune it if you can.
    If I can stay home for more than 3 days not likely I have to do one for @ARamirez73..
    Side note.. @ARamirez73 you between Ethlon tx and Finlay tx last night? I saw a crew way out there as I climbed the long hill on I 10.
    TXRailRoadBandit73 likes this.
  7. Jul 12, 2019 at 3:54 PM
    We are in town in Odessa, we're pretty much finished, we should load machines tonight and the next day will be staying in El Paso, but work meeting up will be in Ft. Hancock
    Mike[QUOTED] likes this.
  8. Jul 12, 2019 at 4:14 PM
    Mike Tread lightly.
    south carolina
    Ok cool.. I will see you out that way...
  9. Jul 12, 2019 at 4:15 PM
    But we should be starting at 5pm
  10. Jul 12, 2019 at 4:26 PM
    Mike Tread lightly.
    south carolina
    Not too bad..
  11. Jul 12, 2019 at 4:28 PM
    Kinda is, too hot, especially for guys on ground, all closed cab machines have A/C, and when you pull out too many ties, rail is under tension and can get away from you
  12. Jul 12, 2019 at 5:03 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What tap and thread did you use for Adam’s? Link? Thanks
  13. Jul 12, 2019 at 5:06 PM
    Mike Tread lightly.
    south carolina
    When I go home I will pull the tap I used to confirm it..
  14. Jul 12, 2019 at 5:30 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
  15. Jul 14, 2019 at 7:59 AM
    Mike Tread lightly.
    south carolina
    cough
    https://atomicfilament.com/ cough.. only from thing i will buy from Amazon when it comes to abs is hatchbox... I would never run china made plastic thru my machine.. Coming from china you dont know what all processes they are using to make it, and making the fumes worst even tho i run hepa filter system i dont want to overload it..
    THo makergeek is gone and under a different name i question them now but honestly, i went tho so much of there plastic and not one jam from them tho when i quit printing 3 years ago commercially.
    i am in talks to come back commercially as few customers i have had said my models where better printed. there current out sourcing is rushing though the slicer and to the machine.
    @ARamirez73.. i will be home next weekend so off it goes to the machine... IF you remember how heavy yours was now it will almost be twice as heavy with the updated version i call 2.0 madmax tundra.... I might have to remote view it but it says 52 hours of printing time...
  16. Jul 14, 2019 at 8:09 AM
    Mike Tread lightly.
    south carolina
    if my memory is right M8 x 1.25 pitch.. confirm it. for me.
  17. Jul 22, 2019 at 4:39 PM
    Mike Tread lightly.
    south carolina
    @ARamirez73 I will be pm you later on this week on details still alot of work left to do..
    Yes it's bigger than the first one and twice as heavy now... :thumbsup:
    So far I'm digging it.. passing my grade..
    6x 4 1/4 inches
  18. Jul 22, 2019 at 6:42 PM
    :eek: :headbang:
