Tires
Discussion in 'Wheels & Tires' started by darkoverlift, Oct 1, 2014.
  1. Oct 1, 2014 at 9:01 AM
    darkoverlift
    darkoverlift [OP] New Member
    brian
    2004 SR 4 Door
    Factory
    What tires do you guys run. My stock tires suck in wet grass and sand. I have 18" bbs rims. It is a double cab 4 door, 2wd.
    I go to the beach often and often wet grass to fish..
  2. Oct 1, 2014 at 10:32 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Stick some nitto or toyo mt's on it. Your rim is a +50 offset, im pretty sure. mt's will help you not to get stuck as easy. If you want to avoid rubbing 33's would be best and in my opinion look the best unless you have over 4 inches of lift. If you do 34s or 35's.
  3. Oct 1, 2014 at 2:30 PM
    darkoverlift
    brian
    2004 SR 4 Door
    Factory
    At most I may level my 04... just living in Florida and driving a 4wd XJ previously I realize the stock tires don't grip in wet grass or sand..
  4. Oct 1, 2014 at 5:11 PM
    I had Toyos AT (315/75/18) on my last one...I'll probably try a different brand when I can lift this one.
  5. Oct 1, 2014 at 10:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Goodyear Duratracs here 315/70R17 ~34.5" diameter. They are awesome on road and off road.
    T-Rex266 likes this.
