Tires
Discussion in 'Wheels & Tires' started by BIGB7051, Mar 14, 2024.
  1. Mar 14, 2024 at 1:49 PM
    BIGB7051
    BIGB7051 [OP] New Member
    Hammond,La
    24 SR5 with 3” factory lift Blueprint
    AMP research XL running boards and 285/75/18 Falcon Wilpeak AT4 and back flip bed cover
    I have a 2024 SR5 TRD Trunda with a 3” factory lift. Truck came with 18” 265/60. Can I install 18” 285/60 and not have any rubbing?
  2. Mar 15, 2024 at 5:38 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Not many have the factory lift here yet. That should be fine and with all that room you might want to go a little taller...
  3. Mar 15, 2024 at 6:05 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Anything is possible with some modification.
    Do some reasearch, read some threads, grab a calculator and figure it out. It's really the only way to know and even then, they may rub when you get them on as all trucks are a little different.
