Tires
Discussion in 'Wheels & Tires' started by recon.fly.nv, Jan 20, 2022.
  1. Jan 20, 2022 at 8:47 PM
    recon.fly.nv
    recon.fly.nv [OP] New Member
    Aaron
    2020 Toyota Tundra
    Got a stock 2020 tundra sr5 crewmax and was wondering if anyone knew the max tire size you can fit without rubbing and without lift kit? Looked online and all I mostly get is the stock tire size.
  2. Jan 20, 2022 at 8:58 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
  3. Jan 20, 2022 at 10:06 PM
    recon.fly.nv
    Aaron
    2020 Toyota Tundra
    that helps thanks!
    Y0TA PR0 likes this.
  4. Jan 21, 2022 at 6:02 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you have the stock 18 inch wheels, you can fit 285/70-18 on stock truck with stock wheels no issues. Few tires available in that size however, Ridge Grappler probably being the best. 275/70-18 is a hair smaller, still 33.4 or so inches tall and has tons of available tire options. I have also been people run 295/70-18 on a stock truck but it really has a stuffed look and may need clearance on the plastics. And if you do a BMC, plastics clearance, bumper spacer you can get 35s in there with the right offset wheels.
  5. Jan 21, 2022 at 6:39 AM
    recon.fly.nv
    Aaron
    2020 Toyota Tundra
    I have the stock 18” rims on there now, also looking to get new rims as well. I looked at possibly going to 20” rims but noticed fewer choices on tires. Thanks for the reply, great info!
  6. Feb 4, 2022 at 5:49 PM
    recon.fly.nv
    Aaron
    2020 Toyota Tundra
    FYI, I ended up getting 275 70 R18 tires with stock suspension. Looks great however I did have to trim some plastic. Wasn’t difficult, however I’m looking at a leveling kit. How high would I have to go up to clear those tires? I’m thinking about getting new plastics once the kit is installed.
