Tires too big
Discussion in 'Wheels & Tires' started by Rbohno, Feb 27, 2020.
  1. Feb 27, 2020 at 5:36 PM
    Rbohno
    Rbohno [OP] New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Had 3” lift put on today and then went and had tires/wheels installed 295/65/18. The front drivers side hit the front of the wheel well and tore up the plastic a little. I fussed at Discount tires and they are ordering me 285/65/18.
    Tires: Duratracs
    Rims: 18 x 9 with +18 offset
    So didn’t realize they were hitting till I drove home and was backing in the driveway and heard some loud running up front when I turned the wheel sharply to back into garage.
    Still have to get my 2” lift on rear, I was feeling ill at the service center and told them to do the front today and the rear on Monday.
    Disappointing to get a 3” lift and 295/65 won’t fit, part of me says to push the inner front fender back and secure and go with the 295’s
  2. Feb 27, 2020 at 5:39 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I bought a cheap heat gun and plastic mallet at harbor freight and lightly tapped my front fender plastic in. Worked like a charm! And alot less hassle than getting different tires
    Sas likes this.
  3. Feb 27, 2020 at 5:40 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Less the tire size and more the offset of your wheel. Buy some bumper shims and be done with it.
    Pinay, TRDFerguson and Mattyc like this.
  4. Feb 27, 2020 at 5:45 PM
    Rbohno
    Rich
    NC
    That’s a thought because I have a heat gun in the shop
    Sumo91[QUOTED] likes this.
  5. Feb 27, 2020 at 5:46 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I ran the Duratrac 295x65x18s on a 2" lift and had no issues. My wheels are a +25 offset but +18 is not that different. I had some rubbing at first and only had to remove the front mudflap and push the liner forward about an inch. Did you get an alignment after the lift was installed?
  6. Feb 27, 2020 at 5:46 PM
    Sumo91
    TN
    I had to do it when I got my 275/70s with 18 offset. Only took a couple minutes
  7. Feb 27, 2020 at 5:49 PM
    Rbohno
    Rich
    NC
    I appreciate the advice but what are bumper shims. I don’t want the wheel stick out farther if you mean shims for that. I prefer wheels more flush with the truck so I initially wanted +35 rims but the counter guy at Discount said no, factory is +60 so you want +18 that will bring wheel out 1.75”.
  8. Feb 27, 2020 at 5:52 PM
    Sas
    OKC, OK
    They move your front bumper forward a bit to make room for the wheel well rubbing issue. You can also remove the front splash guards if you haven't already to get a little more clearance. Sometimes if you are just slightly rubbing, this is all you need. Here's a link for the bumper shims. https://www.tundras.com/threads/sass-will-it-fit-in-the-garage-build.31002/page-3#post-797902
  9. Feb 27, 2020 at 5:52 PM
    Rbohno
    Rich
    NC
    ‘I told the shop that did the lift on the front I would come back Monday with the new tires and rims so they could :
    Finish the job meaning put the 2” lift on the back and then do the alignment with the new tires and rims
  10. Feb 27, 2020 at 5:59 PM
    Rbohno
    Rich
    NC
    WOW, you are brutal!!!
    ‘If I was 20 years younger I may try that but not now. My car guy brain thought that’s what he’s talking about but my old fart brain thought “no way”. But you my friend “are the man”
  11. Feb 27, 2020 at 6:11 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    The difference between +25 and +18 is just over 1/4" so I think that you can get the 295s to fit. Remove the little front mud flap (if DT didn't already remove this) and then unbolt the front liner from the bottom of the bumper. You can push the liner forward an inch, drill a new hole in the plastic and then reattach the liner to the bottom of the bumper.
    This is how I did mine - you can see that the screw on the right is not in the stock hole.
  12. Feb 27, 2020 at 6:16 PM
    Sas
    OKC, OK
    Lol, thanks. Take a look around when you get some time. There are a number of even crazier builds than mine. BTW, I'm no spring chicken either. Had my black balloon birthday a few years back.
  13. Feb 27, 2020 at 6:17 PM
    Rbohno
    Rich
    NC
    Thank you for the great idea. ALL you guys are
    I just can’t remember how to post a pic for the life of me,
    I hit the upload a file button and follow the instructions, so I choose library, choose file size , click done and nothing happens.
    sr5shark[QUOTED] likes this.
  14. Feb 27, 2020 at 6:18 PM
    Rbohno
    Rich
    NC
    That’s even more impressive!, Thanks again
  15. Feb 27, 2020 at 6:25 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I loved my Duratracs. It'll be worth the effort to make these work. Shims will work but I think you can make these tires work with less effort. (I think that to install the bumper shims you need to take your bumper off. This is time consuming if you take the whole bumper apart or a real pita if you take the bumper off in 1 piece).
    285x65s are 1/2" shorter and ~1/2" narrower and IMO will look a lot smaller than the 295x65s.
  16. Feb 27, 2020 at 6:27 PM
    Rbohno
    Rich
    NC
    I just remembered how to post photos.
    Here she is with only the front lift on, Iron Cross steps should be delivered Saturday Fedex.
    Sas, TRDFerguson and sr5shark like this.
  17. Feb 27, 2020 at 6:30 PM
    Rbohno
    Rich
    NC
    Here I the other side from the front
    sr5shark, Sas and TRDFerguson like this.
  18. Feb 27, 2020 at 6:39 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Do the bumper shims and remove the splash guards from the bumper and you'll be fine. All I have for a lift is a level and doing that got 295/70R18s in mine, granted a little less offset at around +40.
  19. Feb 28, 2020 at 9:57 AM
    Rbohno
    Rich
    NC
    Thanks guys,
    Between removing the mudflaps and pulling the front liner forward 2" and re-drilling the holes we are now golden!!!
    Thanks Again for Everyone's Input
    mahmer09 and sr5shark like this.
  20. Feb 28, 2020 at 10:19 AM
    mahmer09
    mahmer09 SR5 4x4
    That's great that it all worked out. Lift/tires/wheel rub can all be a little overwhelming. These forums are a great help. Thinking back to when I had a lifted Tundra five years ago(bought it pre-owned lift already done) to today(bought her new and picked out and had my own lift installed), through this forum and some research, my personal knowledge has grown by leaps and bounds. You would have regretted going with the smaller sized tire after seeing how rad your trucks looks with the 295s. Enjoy!
    Rbohno[OP] likes this.
