Tires tires tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Sep 21, 2016.
  1. Sep 21, 2016 at 1:58 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I know this question had probably been asked a million times but I'm getting ready to put in my toytec 3" lift and was wondering what size tires guys were running with this or close to the same lift. Need to get tires and rims yet. Going to be going with 18x9 rims so any help with the offset would be great too. Want them to look good with fender flares. Any pics would be great too
  2. Sep 21, 2016 at 4:43 AM
    chphilo
    chphilo Tundra addict
    Western PA
    There are different type of fender flares, smooth ones and pocket style ones. I will assume that you are looking at pocket style ones (which tend to stick out more). I think 18 mm is a good compromise between form and function (that's why I went with that offset). If you go lower, you will probably have to deal with body mount chop. Higher will look too tucked in. I have 295/70/18 (about 34.5 inches in diameter). I could not install 35 tires without chopping the body mount. So I had to settle with that size.
  3. Sep 21, 2016 at 7:28 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Thanks. Yeah I was gonna get the bushwacker pocket fender flares and I believe they have 1.75" tire coverage. Don't want them hanging way outside of that but didn't want them all tucked in either and look like a turd. 295 70 or 295 65 were the tires I was looking at just didn't want it to look like they were stuffed in there. Do you have any pics of yours?
  4. Sep 21, 2016 at 7:42 AM
    chphilo
    Western PA
    My sig picture should give you an idea as to how much the tires stick out. Here's a picture from the rear (I posted this picture before in other threads).
  5. Sep 21, 2016 at 9:49 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Cool thanks so 18 mm offset and 295 70 tires. What kind of tires are you running?
  6. Sep 21, 2016 at 9:50 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Nevermind I see Nittos. Nice ride!!
  7. Sep 21, 2016 at 10:29 AM
    TheBeast The Beach
    35" ftw with a 3" lift and aftermarket rims.
    I like Toyo myself.
    Meat is what's for lunch !
  8. Sep 21, 2016 at 11:24 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Nice ride!! Your setup is exactly what I'm doing boss, shackles, UCA'S. You have to do any trimming with the 35's? Also what rims are you running and what's the offset?
