Tires rubbing help
Discussion in 'Wheels & Tires' started by Jwow530, Dec 15, 2016.
  1. Dec 15, 2016 at 8:45 PM
    Jwow530
    Jwow530 [OP] New Member
    Jay
    2002 Toyota Tundra TRD
    hello everyone I just bought a tundra and I don't know anything about wheels and stuff well itnhabe a 2" lift and the wheels are rubbing the frame I think it rubs when I turn the wheel all the way to right or left it don't matter it rubs the wheels are 285-70-17 is there anything I can do to stop it from rubbing so I can turn all the way to park help? I will post pics up Tomorrow and I'm new on here
    NewImprovedRon likes this.
  2. Dec 15, 2016 at 8:51 PM
    TheBeast The Beach
    what wheels do you have ? offset ?
  3. Dec 16, 2016 at 8:32 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    For rub issues, you'll need to find out exactly what part of the tire is rubbing what part of the truck, and then adjust accordingly. I will say, that 2" of lift, seems pretty small for that size of tire. Solution may be as simple as increasing the lift height, as complex as torch work, or as expensive as new wheels or UCA's. Again, it just depends on what's hitting what.
    NewImprovedRon, Law323 and TheBeast like this.
  4. Dec 16, 2016 at 10:04 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Look in the fender well and try to see where they're rubbing.
    Post some pics if you'd like.
  5. Dec 16, 2016 at 10:32 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Like others posted, we need to know where it's rubbing. The most common culprits are the skid plate, body mount, and/or fender liner. If you look under the truck, it should be pretty obvious where the tires are rubbing
  6. Dec 17, 2016 at 2:58 PM
    Jwow530
    Jay
    It rubbing against the metal frame like when I turn all the way to the right or left I will post a pic of the wheel too I just bought the truck and new to all of this stuff
  7. Jan 23, 2021 at 7:20 AM
    Bret423
    Bret423 New Member
    Bret
    Chattanooga, TN
    2019 TRD Sport
    Icon stage 5 w/billet uca’s. Icon hydraulic bump stops, 17” Icon Rebounds. 37x13.50 NRG’s
    Hey man I know this is an an old post but I’m having the same exact rubbing issue with my 37x13x50s. What did you do to solve the rubbing? I was thinking about taking my grinder to it until it clears...
    Funnyguy713 likes this.
  8. Jan 27, 2021 at 6:11 PM
    Evictor
    Evictor New Member
    Grinding your frame?
    Fix for this to add wheel spacer to push the wheels out what are you running wheel width & offset 13.50 is a wide tire
  9. Jan 28, 2021 at 12:51 AM
    Bret423
    Bret423 New Member
    Bret
    Chattanooga, TN
    2019 TRD Sport
    Wheel width is 8.5” with +25 offset
  10. Jan 28, 2021 at 3:42 AM
    You would have to go with a wheel spacer to bring it out. Then you would have to check for other rubbing areas after that....ie front wheel well liner/mud flap area. Never take a grinder to your frame.
  11. Jan 28, 2021 at 8:17 AM
    Bret423
    Bret423 New Member
    Bret
    Chattanooga, TN
    2019 TRD Sport
    I agree with you there. I’ve been looking at the 1.25” Spidertrax spacers. If you combine that with a +25 offset wheel would that be like having a 0 offset or even more negative offset wheel ? Not sure on the math there..
