Tires for leveling
Discussion in 'Wheels & Tires' started by Squirts0717, Nov 21, 2019.
  1. Nov 21, 2019 at 11:07 AM
    Squirts0717
    Squirts0717 [OP] New Member
    2015 Tundra SR5
    What is the biggest size tire I can get without rubbing on a 2" leveling kit?
  2. Nov 21, 2019 at 11:10 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    275-70-18 with zero issues, 295-70-18 with removing front wheel spat (and maybe front mudflap).
  3. Nov 21, 2019 at 12:09 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Also depends on wheel offset. I went up 3.25” up front and had rubbing with 295/70/18 on a +20 wheel. 275/70 will look good, but don’t get any extra width.
    Squirts0717[OP] likes this.
  4. Nov 21, 2019 at 12:35 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    My front is lifted 2" and I am running 35x12.5x18s on wheels with a +25 offset. I have an aftermarket bumper and the only rubbing is on the swaybar at full lock. With My stock bumper I was running 295x65x18 with no rubbing after pushing the front fender liner forward an inch.
    Squirts0717[OP] and MAGDADDY like this.
