Tires for 2023 TRD Pro
Discussion in '3rd Gen Tundras (2022+)' started by Steelhant, Oct 29, 2023.
  1. Oct 29, 2023 at 8:29 AM
    Steelhant
    Steelhant [OP] New Member
    TRD- Pro
    none...new
    Looking for recommendations on 35" tires on the TRD Pro ?
    Thanks,
    Chuck
  2. Oct 29, 2023 at 10:08 AM
    TRDx2
    TRDx2 New Member
    I also went with Wildpeak AT3W’s (to immediately replace the OE versions). I like them on-road for sure, relatively quiet for an ‘all-terrain.’ When I replace them, I may go back to KO2’s (which I had on my last truck) because I prefer them for snow traction.
    highhrider likes this.
  3. Oct 29, 2023 at 10:55 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Did you regear diff with 37's? I know on 2nd gen it's highly recommended to go with different gears than stock
  4. Oct 29, 2023 at 11:40 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Lmao when I looked your tires the first thing that came to mind was fat Cinnamon donuts!
    Eurodriver[QUOTED] likes this.
  5. Oct 30, 2023 at 6:37 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    35" tires will fit the Pro with no to little alterations, I had to zip tie the front mud flaps back a little.
    I am currently running Falken Wildpeak R/T 35x11.50x18 tires. Chose these as they are slightly lighter as they are C load vs E load. They are a little loud but not terrible, yet. I saw about a 4mpg hit.
  6. Oct 30, 2023 at 8:59 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    I have cooper at3 295's - no chafe, no alterations.
  7. Oct 30, 2023 at 9:43 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Did you tune/adjust for tire size in the computer? Don't want to do the exact math of circumference difference to miles but a 32.6" tire to a 35" tire means at 60mph you are actually traveling about 64mph which means at any speed you actually travel more miles than are shown on the odometer. Think if you drove 3 hours at 60mph (at least that's what speed the computer thinks you were traveling) and you actually travel 192 miles instead of the 180 miles shown on the odometer. If the computer were to show 20mpg (9 gallons of fuel consumed) if you take 192miles/9gallons that's actually about 21.4mpg, so maybe its not exactly 4mpg loss?
  8. Oct 30, 2023 at 10:15 AM
    kilocharlie106
    TRD Pro in LR
    No way to adjust computer yet. But yes you are correct. Actual for my tire is 34.8'' so yes it adds up, but still taking a mpg hit even after adjustment.
    Tundrastruck91 and teab[QUOTED] like this.
