Tires are noticeably louder after rotation and balance
Discussion in 'Wheels & Tires' started by Hillsy892009, Jan 11, 2021.
  1. Jan 11, 2021 at 4:01 PM
    Hillsy892009
    Hillsy892009 [OP] New Member
    Vince
    2015 Red Tundra double cab SR5
    So I had my tires balanced and rotated last week (before I personally changed my driver side hub/bearing assembly). The tires are noticeably louder and definitely cupped on the front. (See picture) I don’t know what order they rotated the tires in, I’m assuming front to back because I didn’t notice the noise before. Last year I replaced the factory rear shocks at 110,000 miles with skyjacker blackmaxs. Assuming these tires were cupping while on the back, other than worn shocks, what could be causing the cupping? I have Falken Wildpeak AT3 275/70/18s with about 30,000 miles on them
  2. Jan 11, 2021 at 4:19 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    Looks like there over-sized tires, what pressures do you run?
  3. Jan 11, 2021 at 4:24 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    My understanding cupping is usually an alignment issue, of course rear is not adjustable. How many miles has it been since tires were last rotated? I do believe that 5,000 mile rotation is almost necessary to help curb cupping.
    I also think A/T tires are more prone to odd wear characteristics. My A/T Michelins with 3,500 miles looked to me like they were wearing uneven, so took it to the dealer they checked alignment and was in speck. That said alignment could certainly be better but there not going to do free alignment when in speck.
    Hillsy892009[OP] likes this.
  4. Jan 11, 2021 at 5:03 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    If they criss-crossed the tires when rotating, they are going to make more noise in the short run. The tread on each tire is now running in the reverse direction and it takes a while for them to even out. I had my Dick Cepek's rotated after about 8k miles and the fronts were feathered from the alignment being a little off. After rotation and alignment, they were noisy for about 300 to 400 miles, but have since died down. Until then, get used to the noise.
    Hillsy892009[OP] and MJoeP like this.
  5. Jan 11, 2021 at 6:14 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Tires problem. I had exactly same tires, they started to be loud around 30K and kept going worst.
    I just got rid of them at 40K. I loved Falkens, they had great performance and price point just the noise was terrible. I did tire rotation every 5K and kept proper pressure.
  6. Jan 11, 2021 at 6:19 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  7. Jan 12, 2021 at 1:46 PM
    Hillsy892009
    Vince
    275/70r18 I have a 2.5 inch level in the front and longer rear shackles the raise the back a bit
  8. Jan 12, 2021 at 1:54 PM
    Mulligan1305
    Mulligan1305 New Member
    NC
    2011 Tundra SR5 DC, 4WD
    I've never had Falken AT's but I had Falken's on a car once and the more miles I put on them, the louder they got.
  9. Jan 12, 2021 at 1:56 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    i got the Falkens and they were surprisingly quite for the first couple years but now have recently begun to notice them getting louder. I wonder if the same is true for other brands as they wear as well?
    Piki[QUOTED] likes this.
  10. Jan 12, 2021 at 2:33 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
  11. Jan 12, 2021 at 3:00 PM
    Piki
    Piki New Member
    Probably yes. But Falkens are so bad. They went from kind of ok to very loud in last 5000K.
    I just got enough, they end up in garbage.
    You can compare it to the new toyos at3 before install.
