Tire width
Discussion in 'Wheels & Tires' started by 2010RWtundra, Oct 23, 2018.
  1. Oct 23, 2018 at 6:46 PM
    2010RWtundra
    2010RWtundra [OP] New Member
    Mass
    2010 Rock Warrior
    What width tire can i go with on factory trd rock warrior 17 in wheels with a 3/1 leveling kit? Im going to be be going with a 35in tire but not sure on width or if im going to need spacers
  2. Oct 23, 2018 at 6:54 PM
    15whtrd
    15whtrd Mr. Blonde
  3. Oct 23, 2018 at 6:57 PM
    2010RWtundra
    Mass
    2010 Rock Warrior
    Under that post it doesnt show anythink for 2nd gen with 17 in wheels on it
    15whtrd likes this.
  4. Oct 23, 2018 at 7:24 PM
    15whtrd
    15whtrd Mr. Blonde
  5. Oct 23, 2018 at 9:22 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I first installed 315/70R17 Duratracs on the RW wheels without wheel spacers on a 3/1 lift. It fit but the tire was really close to the stock UCA. I made the decision to add 1.5” wheel spacers to pull them out a bit further. I liked the look and stance. You do have to trim the front wheel well plastic but don’t have to do the cab mount chop.
    1UPPER likes this.
  6. Oct 23, 2018 at 9:25 PM
    csuviper
    Broomfield, CO
    The section width of the 315/70R17 tires is 12.7". If you can find some that are truly around 12” then you should be good without wheel spacers.
  7. Oct 24, 2018 at 4:43 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    it depends on the width and offset of those wheels. I am guessing they are 17x8 +50mm offset? if so, then you can fit a 285 and maybe a 295.
    if you can find a good tire shop, then they should be willing to test fit a couple of different tires for you.
    if you use spacers, then you can fit what ever tire that you want (with trimming :) )
  8. Oct 24, 2018 at 6:18 AM
    2010RWtundra
    Mass
    2010 Rock Warrior
    I think im going just going to go on the safe side and get the spacers and go with the 315/70/R17 tire and leveling kit. Im going with the low range off road kit, looks like a good kit. Thank you all for the replies
  9. Oct 24, 2018 at 6:18 AM
    2010RWtundra
    Mass
    2010 Rock Warrior
