Tire weights
Discussion in 'Wheels & Tires' started by Turtle, Jun 5, 2021.
  1. Jun 5, 2021 at 10:20 AM
    Turtle
    Turtle [OP] New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    For all the Guru's on site, pardons if this has been addressed already. Got 45k on original tires and looking to get new. I understand that tire weights can wreck MPG. Looking at Hankooks at 44 lbs per tire, stock tires are quoted at 40 lbs per tire. Question is will 4 pounds per tire likely to tank MPG? Getting 14.5 to 16.1 mpg depending on right foot now. Will take all suggestions.
  2. Jun 5, 2021 at 10:22 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You won’t notice a thing.
  3. Jun 5, 2021 at 10:35 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    not enough to worry about. 4 lbs difference on standard load rating tires will not be something you really notice. Now if you are going from stock alum rims and tires to a larger and heavier rim and tires that weigh almost 2x stock, you will take a hit.
    Also depends on the type of tire. More aggressive tread and higher load rating will reduce MPG a little. Moving from the 32inch stocker SL load tires in all season or the at2 tread to a larger all terrain in E load will reduce by about 1mpg, and that is based on the new tires being a 33inch. Of course the larger the tire the more they weigh so 34 or 35 inch tires will reduce MPG more like 2MPG.
  4. Jun 5, 2021 at 10:54 AM
    Turtle
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    thanks, looked at a set of KO 2's on E rated tires and they are supposed to be 11 lb increase in weight. so likely see a decrease in MPG. thanks for the info.
  5. Jun 6, 2021 at 9:10 AM
    ultra1988
    ultra1988 New Member
    2019 tundra
    I am looking at the Bridgestone revo 3 in 295/70r18, they are 55 pounds. I was going to go down to a 17” wheel in order to get a non E rated tire, but these are lighter than all the C and D options in 17”. Only concern is ride quality. I hate feeling every pebble in the road with my current E rated tires.
  6. Nov 3, 2021 at 6:39 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I have 65lb Ridge Grapplers now and am thinking about the Revo 3’s as my next set as well. The P-rated 295/70/18 Terra Grapplers are tempting but the durability of E rated tires is also nice to have.
