Tire Wear
Discussion in 'Wheels & Tires' started by Rjlman, Jul 30, 2019.
  1. Jul 30, 2019 at 6:57 PM
    Rjlman
    Rjlman [OP] New Member
    Ray
    2018 Tundra Limited Crewmax
    None - cleaned up all the badges
    Need some help folks. I have an 18 Tundra and just rolled 30K. These are my original tires. Terrible outside wear. My ‘stealership’ is worthless. Is this a function of crappy original tires, bad alignment, etc.? before I install new tires already, I’d really like to prevent this from happening again! EC5BD0BF-AC45-42A2-9C91-3B8D63E309B2.jpg Thanks in advance.
    OR18TRD likes this.
  2. Jul 30, 2019 at 7:17 PM
    Rjlman
    Ray
    It’s all four, equally. The truck is 14 mos old, 30K.
  3. Jul 30, 2019 at 7:51 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    All on the outside of the tire? Do you have a driver or drivers other than yourself?
  4. Jul 30, 2019 at 7:58 PM
    Rjlman
    Ray
    All on the outside...no other drivers. Wondering if my driving is too aggressive? I wouldn’t think so
  5. Jul 30, 2019 at 8:38 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    That’s what I was thinking . I assume you rotated the tires. Front to back. And you have 30k on them... not insignificant mileage. I would have the alignment checked out at a different shop to rule that out. It might be mildly out of alignment toe in equally and you rotate tires front to back and just now see the wear pattern.
    I am really curious to find out the cause because it’s baffling me. And I am running scenarios in my head. It’s like you commute 40 miles on a roadbed that pitches hard left and return by the same route
  6. Jul 30, 2019 at 8:44 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Aggressive driving I guess could do that. Those stock tires do kinda suck, ibreolqved mine at like 25k miles, they weren't worn out but I just disliked them.
    What's your tire pressure?
  7. Jul 30, 2019 at 9:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Add tire pressure and a rear sway bar. Those combined made a huge difference for me. The door psi is a suggestion in my eyes. And a poor one at that! Lol. Try 36-40 psi front.
  8. Jul 31, 2019 at 5:56 PM
    Rjlman
    Ray
    Rotated every 5K, at the dealership. I have had some vibration and pull issues since I’ve owned it. The first 5K insp they road force balanced them and that helped. Seemed like every 5K it was due more tire work...just can’t get past it without either a balance or alignment. Nobody else drives it but me.
  9. Jul 31, 2019 at 5:57 PM
    Rjlman
    Ray
    Anal about tire pressure and try to maintain a warm tire pressure of 36 all the way around
  10. Jul 31, 2019 at 6:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That look like too much toe in. Just get new tire first, install it and get your alignment check. Don't do alignment on crappy tires, sometimes it throw the machine off a little.
    mverkaik and ColoradoTJ like this.
  11. Jul 31, 2019 at 6:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Warm 36 is way too low. Tire pressure is measured cold because “warm” can vary depending on your driving style.
    I would try 40psi cold. I’m guessing you make a fair amount of turns. Maybe curvy roads at speed?
    Remember the stock tires are very flimsy in the sidewalls. You’re getting lots of flex/sway that you can’t prevent. These are heavy heavy trucks
    15whtrd and mambo143 like this.
  12. Jul 31, 2019 at 6:38 PM
    Pudge
    CT
    That's kinda low IMO, I run cold 37 on my Michelin defenders and that seems like the sweet spot for me
    15whtrd likes this.
  13. Jul 31, 2019 at 6:58 PM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    You're lucky to have gotten 30K! I have an 18 with less than 21K and I'm going to have to replace them in the next two months. I rotated every 5K, but sure not on the pressure - probably 35psi cold. They just suck. Same thing on my 2013. Replaced the tires at 25K.
    Pudge likes this.
  14. Jul 31, 2019 at 7:39 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    For the OP.
    This is a similar wear and flexing scenario with even a moderate speed turn. They are not the best tires for this weight truck and the sidewall strength is crap. You probably will have more issues, as did I, before the tread wears out. If you are making turns at speed, they have to flex. I am running a 10 ply truck tire that is heavy and stiff at 42 psi rated for 80 psi. This tire can handle the the weight of the truck nicely and I never worry about tire flex on the sidewall at speed. They are like a nice pair of steel-toed boots.
    Broncobroke and Hbjeff[QUOTED] like this.
  15. Jul 31, 2019 at 9:18 PM
    Pudge
    CT
    I replaced my stock duelers with Michelin defenders at around 25k miled and it was the best thing I have done to my truck. They wear evenly (barely any wear 10k miles into them) ride smooth, outstanding wet and snow traction. They look very average but are a wolf in sheep's clothing
    Broncobroke and ColoradoTJ like this.
  16. Jul 31, 2019 at 9:19 PM
    Kluanie
    Kluanie New Member
    2019 SR5 w/TRD package
    There doesn’t have to be guessing on correct tire pressure, there are utube videos in chalking tire pressure. Get on a straight, flat road or parking lot and draw chalk stripes across the width of the tires, 6-8 lines per tire. Drive straight for 100 feet or so and check that the chalk lines show even wear across the tire. Less chalk left on the outside means more air needed, less left on the center of the tread means less air needed. I generally get 85-90k miles on a set of tires doing this. I hate paying for new tires
    Pudge likes this.
  17. Aug 1, 2019 at 3:15 AM
    The toe in specs on the Tundra is pretty excessive (24* total toe at the high end). After my P Metric craptastic tires wore out, I had the alignment tech take the toe to 6* or total of 12*. Granted I put LR E tires on due to being in a crunch and leaving on a trip. However, these BFG ATs still had good tread on them at almost 60k miles.
    When I was a Tundra newb, I had the same concerns and the people here told me to max out my cold tire pressure and it made a world of difference. It got me ready for the rough ass ride of LR E’s (which I would not recommend).
    15whtrd likes this.
  18. Aug 1, 2019 at 3:52 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I was in the same situation, Everytime I took it to the dealer I complained. They kept showing me the print out of the alignment showing all green yet I still pulled to the right. Service Manager even said it pulled yet when I picked it up after he personally drove it, it still pulled. I took mine to a local shop that's been around for decades, paid him to make it right. He said they had things backwards, what that meant exactly I don't know but my truck now holds center of the road all day long.
    Call the man...
    Wvmoonshiner likes this.
  19. Aug 1, 2019 at 4:25 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I tried a set of those and couldn't get them to balance no matter what I tried. The truck rode like a box truck and my steering wheel shook like crazy. I had it balanced 5 times and road forced once. Didn't fix it. Even had them removed and reinstalled on the rims. I gave up and Discount Tire ended up buying the set back and I went to Dueler H/L's. I am happy with the Dueler's. Truck rides smooth on 18's.
    OP - try running 36 PSI cold. It should help with some of the wear.
  20. Aug 1, 2019 at 4:39 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Still on factory tires and 18s. At 31k I'm at 55% tire tread. As other have suggested outside wear starts with improper inflation.
    These tires wear fast and are prone to flats from road debris. Next tire will be BFG AT.
  21. Aug 1, 2019 at 4:49 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    If there is no modifications to the truck, and the alignment is perfect double check your air pressure and worn or loose parts.
    If all checks out are you taking turns to fast? Racecar drivers call it “scrubbing tires”. It is where the sidewall is pulled underneath during sharp turns therefore the outer edge wears. Hope this helps.
  22. Aug 1, 2019 at 7:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    That is typical of low tire pressure. I run 50 in my BFGs and looking at them last night I bet they go 70k. Lots of hwy. I use to have that problem on boat trailer if I forgot to check pressure often enough. Just a couple of trips on low PSI would do it.
  23. Aug 1, 2019 at 6:00 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Hbjeff likes this.
  24. Aug 3, 2019 at 4:40 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    The tires are below average they put on. With tires like what is on your truck including Michelins I couldn't get past 50000 miles. I now use an aggressive AT Hybrid Nitto Ridge Grappler and the truck drives as it should. I will probably never go back to a regular tire. The tire pressure I run is 38 front 34 rear.
  25. Aug 3, 2019 at 5:01 AM
    I miss the days of getting 30-50K miles out of the tires on my Tundra.
    For shitzngiggles I just went out to my garage to do a tire depth check on my truck. 6/32nds, second set of tires, 35005 miles. After the 600 miles of towing this weekend, pretty sure I will be down to 5/32.
    When the new Tundra comes out with some bigger HP/TQ numbers, tires will wear quicker.
  26. Aug 3, 2019 at 5:35 AM
    Twinky
    07 double cab work horse
    What brand of tires do the tundras come with for OP's year?
    Its not uncommon for new vehicles to have softer, quieter tires stock. I guess that's probably the case for Tundras also?
    Hbjeff likes this.
  27. Aug 3, 2019 at 8:58 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t think I’ve ever gotten more than 30,000 miles out of any tire. Lots of street driving and corners. It doesn’t help that I like to squeal a tire now and again. I guess you could call me an aggressive driver.
    Hbjeff likes this.
  28. Aug 3, 2019 at 11:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My wife does 95% of her miles in the city with her Honda, the tires are just toasted after 30k compared to their 60k mileage “guarantee”
    They are worn on the edges from all the turns and braking is what the tire shop says. Pressure has been kept perfect their entire lifetime
    15whtrd likes this.
  29. Aug 3, 2019 at 11:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If it’s a MacPherson strut design, but tundra is a double wish bone, when the truck turn it should add toe out and more negative camber
  30. May 26, 2021 at 11:23 AM
    Mjunk
    Mjunk New Member
    2015 tundra
    2015 tundra
    I had the same problem
    -.125 camber fixed the problem
